Removing rubber bedliner material?
Columbia, SC
What is the easiest way to remove rubberized truck bed coating from the tub? The po put a rubber coating on the interior of my 40 and I wanted to get it to bare metal to check for any future rust issues and then spray it with line-x. Would brake fluid do it, or do they make something for this?
Jeremy
I waited for a day when the temps were around 30 degrees and tapped it with a body hammer. It came off in huge pieces with no chemiclas ;)
Not oem soundproofing. A roll on paint that the po put on. I tried a wire wheel and it just shined it up. It will scrape off, but that would take forever. Was thinking more of a chemical that will eat it off.
Thanks guys.
Jeremy
maybe try some of that chemical stripper stuff, pretty nasty stuff, be careful itll burn the piss off your hands
What do you guys think about sandblasting it. I thought about the chemicals, and I think anything that will melt the coating will then just smear it around. Could possibly end up with a mess. I think just blasting it off in its current state will be cleaner. I hope. Anybody know where you can buy a decent blaster gun with top mounted hopper that will run off a small air compressor?
Jeremy
Since is rubber like I doubt if sandblasting will do anything to it. When them make head stones they sand blast them and use rubber to cover the areas which they don't want to etch as it protects the stone. Same principal but doesn't work to your advantage.
Ha! I can't believe someone else knew that! When I was a teen I worked for a monument company setting stones. I used to watch the guys blasting the letters into them during breaks. A thin sheet of rubber was glued to the stone then the letters were laid out, then cut with a sharp x-acto blade. They had a huge pressure pot blaster that held 250 lbs of sand. The blasting pressure was 125 psi. Trust me when I tell you the sand will bounce off the undercoating.
I would use a 4" grinder equipped with a coarse, ie agressive, knotted wire wheel. That will remove it but it will be a labor intensive job.
Thanks coolerman, maybe I can talk my brother into doing it for me in exchange for putting brakes and shocks on his truck. I love tricking family.:grinpimp:
Jeremy
Yep, I keep offering to show him things so he can do it himself, but everytime he shows up he just wants look at the tires and stuff and talk about what if you did this or that. Oh well, some people are just not interested in the technical stuff I guess.
I had my third member out and wanted to show people how cool it was that it dropped out and show people how it worked while it was out, but knowbody was interested. I guess I just like seeing how things work. Chat done.
Thanks for all the help guys.
Jeremy
I used 3M woodgrain and stripe remover. Found it at an auto paint supply, but its pricey. Around $20+ a can. Spray on, watch bubble, scrape off.
Xylene is main ingrediant in this product I believe.
Try some brake fluid. Someone on here posted about it removing the liner. No actual experience, but its got to be cheaper than paint remover.
