removing 3rd member
I am brand new to the toyota axles. I have the whole thing apart, except the 3rd member removed. I can't get the sob to come out. i have used penetrating lube on the studs, chissle, and a BFH with no luck. am i missing something here to release it.
If you have the axle shafts out and have removed all the nuts/bolts around the outside of the 3rd member, it's just being held on by the gasket.
Put a floor jack under the pinion flange and break it loose. Then be careful - it's heavier than you think when you're laying under it.
I agree, use the floor jack to gently lift the pinion flange, this seems to break it loose and you can pull it back and drop it. Not litterally of course...LOL
thanks for the reply's. Yeah, unfortunently i have the axle out, so it should be tough. Yes, i do have the shafts out and the knuckles completely taken apart.
Flat tip scrrewdriver right where the diff meets the housing...
The only good use for crapsman combination pry bar/chisels... :)
Get a good sized hammer, and drive the screwdriver into the area where they meet...
You will get it to seperate.
Good luck!
-Steve
Good luck!
-Steve
That is the only method I got to work for me, but then again I didn't think of the floor jack. Just remember that 3rd member is mucho heavy. Scared the s*** out of me. Have fun.
my64fj40
Poser said:
It would be difficult to get a floor jack to work on an axle that is not under the vehicle tho...
:beer:
Yeah me and my silly assumptions. :doh:
I always hate to mar up a sealing surface so if the screwdriver trick doesn't work or you get a chance to try it, a come-along from the pinion flange to the long-side end of the axle housing might get you enough leverage to pop it off. You just might have to get creative with the cable routing so you don't crush the pinion seal dust cover.
I used my cherry picker to seperate them. I put the axle tubes underneath the pickers legs, and bolted the short side of the drive line flange to the diff with a tie down between the pinion and the flange. I then attached the tied down to the picker arm and jacked it up, which popped the pumpkin out..
good luck!
Dustin
I used my hilft as a comalong. Tied one end of the hilift to the rear axel. Tied the claw to the end of the third memeber and started pumping away. :D I had an old rim with a blanket stuffed in it to "catch" the 3rd when it fianly poped lose. good times. Scared the pop out of me when seal finaly broke.
well, i got the 3rd out. I just beat the hell out of it with my largest hammer and a chissel. The sealant is like cement on there, its gonna be terrible cleaning the surface. Any good solvents for softening the gasket and glue?
3M gasket removing pad in a die or 90* grinder. Comes off easy but does throw debris all over including inside the axle housing.
Ditto on the screwdriver and BFH deal. I took a small file and straightened out the mars I put on the gasket surfaces. I like the jack suggestion and will try this next time before I remove the 3rd.
