where did you mount the cable pulls?
Bill I made a bracket and mounted both pull handles under the driver seat. That installation is completely detailed in my build thread.
Auburn LSD for me, WHY:
1. No leaky plumbing, no air tank, no installation kit, no cables.
2. Completely highway manageable, no noise, no wheel hop.
3. On road and off road additional traction.
4. Because they are working ALL the time, they are locked before you get to a mud puddle (obstacle), so most the time you can drive right through it without having to go into 4WD. Rock crawling with one wheel in the air, not so good, but I never was a rock crawler, almost always had some degree of weight on each wheel. Problem with LSD's is with one tire spinning in the air, you have to tap the brake pedal to get more power transferred to the tire on the ground. The original LSD's liked to give more power to the tire that will spin the easiest (tire in the air), but Auburn changed that to giving more power to the tire that already had the best traction- - -home run.
5. Option, instead of running psi fluid you could run regular gear oil, then the LSD acts more like a solid locker, clutches do not slip as easy, and you do notice some wheel hop in corners. We use to supply desert racers with LSD,s and they ran regular gear oil for more of a locker affect.
Thanks, I'll check it outBill I made a bracket and mounted both pull handles under the driver seat. That installation is completely detailed in my build thread.
Went with a Powertrax No-Slip locker, same functionality as other lunch box lockers but without the click in corners. Great off road and pretty well mannered on the road. Picked up an ARB a few months ago from a friend but haven’t decided if it’s going in the front or rear. I don’t wheel but a couple times a year and I’m not heavily built so part of me thinks adding a second locker in the front will just get me in trouble (i.e. I will tear up a pretty clean 40)
Off topic: So I locked the rear last year and my gear head desires tell me to lock the front as well. My reluctance lies in the fact that I haven’t upgraded the axle shafts. Are people confident that lunch box style lockers aren’t snapping birfields and shafts? I’m more wanna be crawler, than hardcore wheeler, but I enjoy building things...Love the front end locked you will love it.
1,000 years ago before there were any brands of positraction devices available for Landcruisers we use to remanufacture GM Govlocks for the Landcruiser (only game in town at that time). The Govlocks had two problems: (1) One tire would not lock up until the other side was in a full spin. By the time both sides were locked it was frequently too late, you were already stuck. (2) When the Govlock in fact locked it was fairly violent (inside the differential) so they would frequently snap/break the actual locking mechanism, the gears were tuff, the locking mechanism was frail..What happens with your eaton govlock you used to offer for sale. I have one of those in my 2004 AWD Astro and it actually works really good. I wouldn’t mind trying one of these in a daily driver weekend warrior in a 40
