Hello. With everyone's help, I am about done with the SOA project.
I have tried a few things contrary to what has been suggested, but here we go.
Put the tires on last night to check for ride height, caliper fitting etc.
These are 37x12.50 TSL, with 4" backspacing beadlockers:
Rear pinion angle is 20 degrees. I re-welded shock mounts to incorporate the OME long travels.
A front view - custom 7" shackles created at a 50 degree angle for max droop and articulation (proven tests to follow) - Driver fender removed for Astro power steering project (pictures to follow).
Custom machined steering arms. These are Mini-Truck knuckles. I had to hunt down M12x1.25 Nuts to fit. Not pictured: I am using 1 ton Military H1 Hummer Tie Rod Ends. They are MONSTERS. The other cool thing is the zerks are side mounted, so nothing will catch em.
I reversed the front perches, and machined my own shackels out of 1/4" plate. I then used 1.5" tubing and fab'd a support.
I am just test fitting and measuring at this point, I will clean up and paint shortly.
Testing, finished project to come shortly. Almost there!
Ragman
Ragman
