smilar current thread:
https://forum.ih8mud.com/showthread.php?p=1183178#post1183178
edgemonster said:I just dropped in a BeCool #62167 from Summit to cool my 5.7l Vortec. Installed in less than 2 hours (new thermo and complete flush). I've been running the radiator for 2 weeks and the temp rarely goes above 190. I had to can my old shroud. BeCool's claims of 20- temp drop is no bull. With my old 2 core shrouded I could bring it up to 200+ on some of the grades around here. I know your looking for something cheaper, but for me it was worth every penny. Can't wait to get my tranny gauge working again to see the temps.
Does the aluminum radiator come with rubber isolators to minimize the galvanic reaction due to dissimilar metals being in contact with each other? I realize that the aluminum mounting flange is most probably a 50xx series and a couple steps from steel on the galvanic series chart (the wrong direction I might add). If you do get a reaction it is going to oxide the aluminum more than rust the steel. Personally, I would mount an aluminum radiator with rubber grommets to maximize the isolation. But then I've often been accused of suffering from ARD (anal retentive disorder).edgemonster said:I just dropped in a BeCool #62167 from Summit to cool my 5.7l Vortec. Installed in less than 2 hours (new thermo and complete flush). I've been running the radiator for 2 weeks and the temp rarely goes above 190. I had to can my old shroud. BeCool's claims of 20- temp drop is no bull. With my old 2 core shrouded I could bring it up to 200+ on some of the grades around here. I know your looking for something cheaper, but for me it was worth every penny. Can't wait to get my tranny gauge working again to see the temps.
dgangle said:yea, but this thing is now almost 700 beans!
bsevans said:Does the aluminum radiator come with rubber isolators to minimize the galvanic reaction due to dissimilar metals being in contact with each other? I realize that the aluminum mounting flange is most probably a 50xx series and a couple steps from steel on the galvanic series chart (the wrong direction I might add). If you do get a reaction it is going to oxide the aluminum more than rust the steel. Personally, I would mount an aluminum radiator with rubber grommets to maximize the isolation. But then I've often been accused of suffering from ARD (anal retentive disorder).
mdjohnsen said:Ok. Now we're talkin'. $160 is well within my price range. Also, I see that it is a single row. I've seen others that are 2, 3, 4-row. What kind of difference does this make?
http://store.summitracing.com/partde...5&autoview=sku
In the absense of current flow I doubt you would see much galvanic reaction. Even with current flow you would need a carrier, like salt water, to see much migration. This is why aluminimum and steel body panels can be used together with no problem.bsevans said:Does the aluminum radiator come with rubber isolators to minimize the galvanic reaction due to dissimilar metals being in contact with each other? I realize that the aluminum mounting flange is most probably a 50xx series and a couple steps from steel on the galvanic series chart (the wrong direction I might add). If you do get a reaction it is going to oxide the aluminum more than rust the steel. Personally, I would mount an aluminum radiator with rubber grommets to maximize the isolation. But then I've often been accused of suffering from ARD (anal retentive disorder).
mdjohnsen said:
I don't know if it's stock or not. I'm assuming the dude that sold the truck to my seller tried to convert everything. The dimensions are:
