Radiator
mdjohnsen said:
Here is my current setup. Any changes need to be made as far as my radiator?
Shroud, and maybe a spacer on your fan to get it closer to the radiator....and a shroud;)
GL
Ed
mdjohnsen said:
You're killin me. Plastic? :censor: I don't know if it's stock or not. I'm assuming the dude that sold the truck to my seller tried to convert everything. The dimensions are:
36"L, 2.25"W, 17.5"H
Alot of the new cars have plastic ones
It looks like the PO pulled the radiator mounting channel. What are those bolts attached to? 36" is way longer than stock. Is it resting on the inside of the fender well. The core looks like a single. Is the 2.25" measuring the filler neck?
A shroud is worth its weight in gold. Focus that air flow.
The fan blades need to reside just inside of the shroud with the shroud sealing around the radiator. Air flow should be concentrated to pull through the radiator. With the shroud onstalled you should be able to place your hand in front of the radiator with the engine idling and feel air flow pulled into the engine compartment. If you've got a local fab shop or you can do some sheet metal work, fab your own for your situation.
