So, I've been having overheating problems. It's a familiar story if you read here much, and other forums, too. I could recite the same litany of "did you check this, did you check that" from Isuzu diesel conversions (Wheelingnoob - sheesh! It was like reading "Lord of The Rings") to Subarus to other regular 80 series trucks.
I won't go through all the gory details, but it's load / speed dependent, not airflow dependent, and EVERYTHING in the cooling system has been replaced / serviced / checked.
Going faster runs hotter! It's almost linear, and pretty darn repeatable.
One last nagging doubt before I have the head gasket replaced :
Are you SURE that brand new CSF 2517 old school all metal radiator is OK? Maybe it's just a piece of crap. It's made in Thailand or somewhere. Maybe the tubes are all full of solder or flux or elephant dung or something. It's only brazed copper after all, and nobody uses THAT anymore, you know!
OK, let's just see about that!
Radiator flow rate test setup:
Stopwatch.
1 willing helper.
5 gallon plastic bucket.
1 1/4" PVC pipe.
1 1/4" PVC elbow.
1 1/4" PVC male thread adapter.
1 1/4" to 1 1/2" PVC thread bushing - as a retainer nut.
1 1/4" slip plug.
Heater pipe insulator foam - gaskets.
1 1/2" radiator hose - InFlow and OutFlow adapters.
Head pressure : Bottom of bucket is roughly 14" above radiator inlet.
Test volume: A bit less than 5 gallons.
Step by step:
1) Plug Outflow pipe.
2) Fill plastic bucket with water to rim.
3) Get stopwatch ready, watching inside the bucket.
3) Have helper pull plug (start timer).
5) Water level down to top edge of pipe (stop timer).
Measurements:
Old OEM radiator, 2 row aluminum core, plastic tanks, no visible sign of build-up or blockage.
10.8 +/- 0.1 Seconds.
New CSF 2517 radiator, 3 row, all copper/brass.
6.7 +/- 0.1 Seconds.
Yeah - you heard that right! Seconds!
You have to be fast or you'll miss it. Like flushing a toilet - no, faster!
Well, you can argue about high or slow flow rates having better cooling capacity, but really, that's for heat exchanger engineers. They'll both work just fine, thank you.
Oh, one last thing: FOR SALE - CHEAP - Calibrated Radiator Flow Test Set. (Phoenix area preferred)
Anyone want to add their data?
Here's the test setup assembled and ready to go with the dismounted old radiator.
I love the juxtaposition of "DANGER" and "KEEP OUT OF REACH OF CHILDREN" and that lovely happy child. Nice.
Stopwatch.
1 willing helper.
1 1/4" PVC pipe.
1 1/4" PVC elbow.
1 1/4" slip plug.
Step by step:
Measurements:
