Question about a pulley
Fayetteville, North Carolina
The pulley in the photo has 2 areas that appear to have some type of caulking? What is it? Can it be replaced? The reason I ask is that I wanted to powdercoat it.
I'm not sure you want to remove that. That's balanced most likely.
Thats called " VULCANIZED " Rubber
its how they assemble , and bond all the pieces without the unbalanced approach or welding
very similar to a motor mounts of a 2F fronts
Those two grooves on the seal surface were caused by an old hard seal. They are VERY deep and will cause significant leaking out of the front crank seal unless you put a repair sleeve over it.
Put a speedi sleeve on it and Spray paint it. If you went the powder coat route part of that process involves being baked in a oven, not so good for rubber.
I don’t think that is the right pulley for AC on an fj40. As Splangly said it is basically trash anyway. You need a 3 grove pulley to run AC.
It is a 3 groove pulley. I want to run an AC and an OEM PS pump
Looks to me like it already has a speedi sleeve on it. Might want to check and remove it if it has been sleeved already. I could be wrong but it looks like a seam at the base of what should be the polished area.
