PTO winch
The PTO winch that came with my FJ40 was a total workhorse. I used it to pull stumps out of the ground, move brush piles, and pull other rigs out of trouble. The times it let me down was when I was self-recover mode. I sheared the pin 3 times and was left waiting for a buddy to finish the pull.
What I really didn't like about the PTO in self-recovery mode is I couldn't use the tires to help motivate the cruiser out of the situation I was in. The tires want to run at a much greater speed then the PTO for the same gearing. For instance, as described by 65swb45, I was pulling myself up a waterfall using only the PTO. About 3/4s of the way up the shear pin popped leaving me stranded on the drop. I engaged the wheels and could climb about 6" before I would loose traction and drop back against the cable. I now have an electric winch and run the winch and tires together and am much happier with the results.
If I were mostly using the winch for work applications I would want the PTO back. I use the winch mostly for helping get myself further down the trail and for that I prefer an electric.
I've heard/read (self-recovery) this a lot about PTO winches. I was thinking that if one replaced the shear pin with a bolt and with all the pulling power of the PTO, the tire motivation point becomes moot IMO.
Has anyone used the pto to run something else, fsay an Air compressor, seems like that would be kind of handy, or maybe a hydraulic pump to run a hydraulic winch, Jack something else? seems like a 2" cylinder with a base and a valve mounted on it would make a pretty neat highlift, especially with some pilot op. checks to act as a lock. to much valving I guess, but I think the air compressor would be nice.
I don't know I really like the abil;ity to have the hand control and be able to bump the winch to help me over objects. The ability to reverse the winch instantly especially comes in handy when your tire is binding aginst something to prevent suspension or steering breakage.
I replaced the pin with a bolt the first time it snapped, as I recall the bolt I used was grade 8 and I sheared it too. I think I sheared that pin/bolt at least 3 times. Maybe I'm harder on the PTO then most, who knows? But I definitely like the electric better, for "my" applications.
By the way, a PTO wins the cool factor hands down.
Advent said:
You wouldn't need to swap anything. My PTO box has both front and rear outputs.
Split-Case PTO units were available in both F only and F & R outputs. I am pretty sure the 1 piece T-cases were available as both also.
For those looking for a rear output, there is also a PTO head the bolts to the back of the t-case (as opposed to the side) that had a rear facing output, they were used for water pumps, hydraulics, etc... There has been a couple on Ebay, and I know SOR has em too.
This entire COMPLETE setup was sold on Ebay last year, went pretty cheap too as I recall...
COOL PICS!
I haven't seen one new in a crate like that since 1979......... :eek: I sold a couple back then.
cruiserdan said:
COOL PICS!
I have a couple more too... as I recall the guy had had it sitting around for years and long since sold the Cruiser. I want to say the entire setup went on ebay for ~$800, a steal for BRAND NEW... Does anyone remember the whole deal? I thought it was actually posted here for sale too?
i dont know about solid rock but ive used my pto and tires by running the truck in lowrange and the winch at the same time and it works well drilled out shear pin hole to 5/16 and use cap screw now it breaks the cable once rescued 3jeeps and blazer because all there batteries went dead took 4 hrs of steady winching to get them all out and they were happy just for luck i have a 6000 ramsey on the rear electric but havnt used it yet but you never know in the end use what works best for you and enjoy your rig
