PTO winch
SoCal
Other than the nostalgia factor, which is admittedly valid, any reason to choose one over an elec.? Can you run a PTO winch off a split xfer case?
Welcome.
Yes you can run a PTO off a split case.
I have been very happy with my 8274 and now 8274-50 Warn, and would not think of installing any other winch on the front of my Land Cruiser.
I have a 72-40 and a 77-55 that both have PTO winches....they are neat, and work well.
Good luck!
-Steve
If the reason you need a pull is because you stalled, then the PTO won't do you any good!
The best program of real life winching do's and don'ts I ever saw was running Surprise Canyon on a TLCA Thanksgiving run. 10 rigs, winches MANDATORY. You literally had to winch up 6 waterfalls to climb the canyon, and two were too steep to drive down either! :eek:
Only one rig had a PTO. The shear pins gave way. Marlin ended up welding the PTO together so it wouldn't shear any more!
My buddy ran his electric winch until the battery died! Had to jump start the truck and leave it on a high idle for 3 HOURS to recharge.
One of the other electric winches in the group failed. I forgot the brand.
Most people will never have to winch this much in one day. ;)
as stated, PTO will run forever (as long as engine is runnung).
Electric works if engine has stopped (or if you're upside down) :)
PTO is a lot stronger - been on a trip, 8274 had to pull tripled through a bog, I did single pull (probably should have doubled but didn't).
in the end, it comes down to how much, and what type of trip and winching you do.
there are lots of different views.
Personally, I'm very happy with my PTO and wouldn't change it...
This is a good comparison. PTO vs 8274 they both have advantages. Pto beats any other electric winch hands down but the 8274 is an anomoly.
One thing that hasn't been said is that when your engine quits (like whe you're upside down for instance) you can still use your PTO by pulling the sparkplugs and running the starter motor. Voila, an electric winch!
PTO on the front. Electric under the tail. Best of both worlds. ;)
Mark...
The PTO was a good winch, it's a total work horse. The previous owner had modified the sheer pin to accept a 1/4" pin. Which did help on really hard pulls, I only blew one pin, but I was detained on a tree stump when that happened. I have pulled 2 cruisers up at once with the PTO. The downside is that it is really slow and if your engine can't run the PTO won't run. Plus it's a heavy mofo, I think around 114lbs (including winch head, shaft, and gear box).
Mark...
x2.
I have had both,electiric and pto- eliminated the shear pin (the only thing I have broken since is a cable). Works amazingly well, reliable. My electric ramsey 9k was bought used, and worked well, but would overheat often.
Just to kep in mind, most industrial apps- (wreckers, log skidders, tractors) all use PTO for two reasons. Strength and reliability.
Nothing wrong with a good electric winch, I just like the PTO a little better.
I've got a PTO on my BJ60. It was a takeoff from a Japanese import. The PTO takeoff I have doesn't have a reverse (other than reverse gear) like my daughters PTO takeoff on her FJ55 single piece case.
Those that had shear pins snap, were they OEM toyota shear pins? I've heard others have problems with various things they were using as sear pins. I also have to say, they're fast... put tranny in 4th and give some gas..
Thanks for the replies, people. I'll be asking more questions in the months to come while I'm putting this 40 together.
Vic
Redlands
Mine snapped twice, both brand new from toyota. They were cheap, I bought 5 or 6.
Go with something bigger, or eliminate it. I have heard tale that the next weak link is the broze (brass?) gear in the winch head, though I have never seen one fail of the 4-5 guys I know who use PTO.
Cables, yes. Even new. That is how hard that thing will pull.
andrewfarmer said:
PTO will winch at whatever speed you ask it to.
If it's too slow, change up a gear - a pto winching in top gear is NOT slow!!
Eh, even in 4th gear with the engine reved up an electric winch was still faster.
I'm surprised - my winch/pto combo is slower than Toyota OEM and even in second (at around 4000rpm) I'm pulling faster than any other winch I know (except Toyota OEM which are faster again)
This includes many makes of electric, various PTO (note many non-Toyota drive off the gearbox not t/case and changing gear doesnt alter speed) and even some very hi-tech hydralic systems...
Personally I wouldn't winch or wind in in 4th - too fast and too dangerous... 3rd is about as fast as it's possible for someone to feed in cable by hand and even thats at low engine speeds...
Uh... i would be scared to see my 2f at 4000rpm :flipoff2:
I ended up ditching the PTO because it was big, sat low in the frame rails, and wasn't too pratical as I modify my rig more towards rock crawling. Great winch though total work horse.
Someone here know what kind of model/year PTO can fit on a 1985 BJ70 ?
FJ/BJ 40-42-45-60-70-74 ?
Contact Greg or Sheldon at G&SCruiserparts.
