Build Previously known as the 'One Week Resto' now Pathetically keeping it alive... 500k
Continuing with the little things… made a bushing for the oem soft doors… the hole was so big that the door was about 3/4 open and when I hit a good bump it would swing open lol
I was running a bungee for the last month so that didn’t happen
Came out decent … it works and is functional
Closes tight
Now if I can only find a lower weather stripping channel for this door…. This was a replacement I made 12? Years ago and it rotted off… the weatherstripping is holding it now :meh:
@Living in the Past That happened quite awhile ago … one day it snapped off when driving luckily the outer and inner handles stayed put
I drilled it out and taped it… both sides are this way
I think it was the Dside that had broken off long ago and we welded it… but when it was time to recanvas the door I drilled and taped it
You just have to make sure the shaft it a tad longer than the handle so the screw bottoms out on the shaft and not the handle or else it loosens up because of the play in the square holder
If that makes sence
Works well … and to honest I was originally trying to weld on a stud … but looked like s*** and broke off a few days later … so went with plan B :meh:
More continuation of the little stuff
New cap and rotor … inside dizzy didn’t look too good so the weights must be rusty … shot a bit of oil in … I’ll have to remove it at some point and take a good look inside
But good news plugs looked great to me
Had a used set that I had in reserve that were blasted and cleaned and regapped ready to go in … these will get cleaned and go on shelf for next tune up
To check the weights freedom, with the rotor on, you should be able to twist the rotor one direction or the other and it should snap back to its original position when released. It shouldn't take much to move it. The resistance is just the springs.
Yeah I checked for movement … when I saw that… not much … wishful thinking the oil will free it up lol
I checked the vac advance and that was working as it should … so it’s not getting full advance as it should
I will most likely get a cheapo electronic dizzy for the time being from AmaDum
If your gonna go that route I have a spare you can have.
A few more little things….
Had to get new rotors as it would not pass inspection… got them opened to 4.175 and new cheapo pads… and replaced all 4 shocks with KYB … the rears were replaced (yellow ones) about 10 years ago (monroe) the fronts totally dead but for good reason they haven’t been replaced in 30 years they were the original Heckathorn shocks when I did the suspension lol
The only issue was the rear upper mount the stud end snapped off … welded a new end on… my welds suck… but when it’s together only I will know lol
…the fronts totally dead but for good reason they haven’t been replaced in 30 years they were the original Heckathorn shocks when I did the suspension lol
This is when you’ve long ago reached your own PO status. Love it!
keeping up with doing things here and there…. So next up was replacing the Speedo cable that I had on the shelf for 20+ years
My cable had fallen on exhaust and meted away then wore out the section you see … I zip tied it until I could get to it… it was still working …soooo it stayed like that till now lol
Cleaned the cluster in and out
Topped off the tranny (no leak) and transfer (had a leak so it took a bit
Added a second layer to the fastener cover as the single layer started to punch through
Trying to get windows back to original spots … basting tape holds in place the new windows in order to sew in
Sides are done
Onto the back
Day two … quarter windows on rear as well as the Johnny door … in a way the rear door would have been so much easier if it were a normal one piece roll up lol
I do like the split window and being able to roll one side … behind the tire I usually roll and keep the driver’s side down when I have people in truck … keeps the fumes to a minimum :meh:
10 years outside 24/7 killed these windows … in 10 years I may make a new and improved top and see about doing hard windows
What is a Johnny door?
Any thoughts to having garage space for it in the next ten years? My hope is within the next ten years is to have my second garage insulated and and air conditioning. This time of year a evaporative cooler doesn't help.
That’s what a buddy from work called it when he first saw the single side back door open … like in “here’s Johnny”
Done enough …
all windows were only single stitched in … at some point I’ll take it off and put a second stitch … and correct minor sew issues
Done enough …
View attachment 4178149View attachment 4178152View attachment 4178153View attachment 4178154
Well after that project is in the dust I think you need to practice a little more with building one for me…..plus I don’t need a Johnny door.
