Got a package today. Group 27 battery tray, hardware and shims. I can't believe Toyota still has this stuff manufactured. Glad they do though. I also got a second cig lighter for accessories. Still trying to figure out how to install the radio.
I did my o2 sensors this Friday. Jacked it up in front of my house and went at it. I used WD40 specialist rust penetrator, hammer, flat head screwdriver, small chisel, dremel with extension and cutting disk, and lots of patience...took me like 3 hours to take the nuts out. I sprayed it with WD40 just before starting (not recommended, but the WD40 is good stuff), then tapped them with screwdriver, then chisel, then made some groves with the dremel, then some more tapping...and they were out. Nuts were 27 years and rounded from corrosion. At first it seems that it is not possibe, but it can be done. That said, I think it is worth paying someone to do it if the nuts are in really bad shape. I did mine, but would not do another set in such bad shape. Good luck!I need to grow up and get some air tools. No garage is tough though. A puma 12v compressor might be in the cards at some point.
Willya be at the relic run????
Yep me and carter will be there in the 60Willya be at the relic run????
