in my case the ""like" is hoping to encourage you to continue sharing these nuggets of electrical wisdom!Ok, I get it. Not surprised.
I’m sure you guys are posting “likes” because I said I was shutting up not because you like the Anderson mounting idea.
Sickkkk. How do you like those locking rails? Is it the vevor brand or another one? My buddy helped me build my diy bambed platform that I can disassemble to make it easy for storage. Thinking of putting rails on the inner side of the legs to have 1 drawer.Working on my cargo area drawer setup, V2.0 reboot...I took apart my first one to scavenge a lot of parts. After a fair bit of research on other options out there, I gleaned a lot of info for build style, materials, and mounting options. I decided to go a bit lower with V2.0 and will do a single large drawer that about 32"x36"x8" which should give me a lot of great space. I'm also doing a separate attachable module for the front where the middle seats go on the passenger side to make it a full 6' sleeper section with underneath storage too...this can be removed if I want to put in the passenger side middle row seat if needed. I'm also doing a slightly lower platform in front of the spare to hold my new Iceco fridge...I got a smaller 47 quart dual zone that fits perfectly there right behind the driver. Lid opens both ways or you can just pop off completely to load/unload from inside or outside. This should all tie in nicely and will give a lot of stowaway space for my Mojab hydraulic jack, power tank, and backup fluids/parts in front of the drawer box (for tools, cooking, etc.).
Materials wise, I'm using a 1/2"x3"x48 flat aluminum bar (4 pieces) to be able to bolt on to existing floor points, then use the right angle tabs to attach the box to them for ultimate security and no straps or turnbuckles. I also plan to get a full sheet of bamboo plywood for the main finishes...I love the look and it's nice and hard! Not cheap, but I think 1 full sheet will be close to getting it done. There is a flooring supplier on the south side of the Baltimore beltway that stocks several styles & thicknesses...I have some samples coming to confirm what i want. I can then order and pick up myself so I don't need to worry about crazy shipping costs.
Here's some inspiration from another forum member in CA that builds these...I'm doing a hybrid version using his styles, but doing the extruded framing like the ADGU option rather than an all wood construction. One pick is of the 3/4 size that I'm doing with the inside spare, and one is with the bamboo plywood.
And then my progress so far...I have the main box frame fully constructed and need to measure out to get exactly what I need for the 2 front boxes now...super amped at how V2.0 is coming along! The slides for the drawers are very hefty, and claimed to hold 300+ lbs...they are a beast. I have 5 attachment points on each side, so they aren't going anywhere!
i wanna see the inside of that transMaking some progress! Got the H55 trans and TC removed, rear main oil seal (had been leaking forever) replaced, pilot bearing replaced, and flywheel dropped off at the machine shop. New clutch will be installed after the flywheel comes back. I was really excited that my exhaust unbolted from the header without a fuss...I thought for sure at least one of those studs would snap. I have to replace the tach sensor that screws into the bellhousing, as it suffered broken wires on removal, and I can attest that the tariffs are real on imported parts (I had to order this one from MegaZip in Japan). I was shocked at how much a replacement costs. There is also one wire in the trans wiring harness that broke at the plastic connection while fighting to get it apart, but I think I am able to fix without too much trouble.
Now to get the trans and TC up onto the workbench, take apart the split case TC and rebuild the TC onto the new H55! At least the process is fresh in my mind.![]()
That's very er, progressive of you @TRDdrew. And you think you know someone!!i wanna see the inside of that trans
Never know what you’ll find once you twist a few nuts off…That's very er, progressive of you @TRDdrew. And you think you know someone!!![]()
Crikey!Never know what you’ll find once you twist a few nuts off…![]()
Where'd you get that sunroof rubber? I didn't think Toyota made it separate than the glass.New sunroof seal, Dobinsons torsion bars and OME LCA reinforcement brackets.View attachment 4070918View attachment 4070919View attachment 4070920View attachment 4070921View attachment 4070922
