Toyota but it’s for a 100 not an 80Where'd you get that sunroof rubber? I didn't think Toyota made it separate than the glass.
Andrew is getting saucy, lol! I figured that we would have time to take a peek when y'all come over to help me stab the tranny back in. Late February probably.i wanna see the inside of that trans
@iptman here are some close ups of the 100 seal. Maybe it could be made to work. I’m sure others have tried to find a suitable fix though.Toyota but it’s for a 100 not an 80
I’m not nearly as annoying thoughDang.... @NearJetties looks just like that car care idiot on Youtube!![]()
Debatable..I’m not nearly as annoying though![]()
did you consider plugging the fridge into the Jackery, and the Jackery into the truck battery? so when the truck is off, the fridge always runs on the aux batt, but when the truck is on both the fridge is on and the aux batt is charging?WARNING: Geeky stuff to follow.
My Dometic fridge plugs into the cigarette socket in the back of the 4R when we go on a road trip. Since the cig socket is only powered when the ignition key is on, when we stop somewhere I have to unplug the fridge from the 4R's socket and plug it into my Jackery Portable (Aux) Power box to keep the fridge running while the 4R is parked. And then reverse the process when we hit the road again. Truth: I do have a bypass switch to keep the 4R's cig socket powered when the ignition key is off, but if we are parked for a long time, I would prefer that the fridge drains the Jackery battery rather than the one under the hood.
So, to eliminate the exhausting, time consuming and annoying process of plugging and unplugging the fridge I came up with a simple circuit to do the switching automatically.
A simple DPDT (Double Pole Double Throw) 12 volt relay is all it takes. When the ignition key is off, the fridge is powered by the aux (Jackery) battery. When the ignition key is on (4R's cig socket powered) the relay is energized and the 4R powers the fridge.
Here is the circuit:
Here is the box I made:
Finished project:
One cig plug goes to the 4R's cig socket (IGN) and the other one goes to the Jackery (AUX) power box.
The Anderson connector on the side of the box is for the fridge, I made an adapter to go from the Anderson connector to a cig socket. I also have a power cord for the fridge with and Anderson connector (best of both worlds). So when the box is in use I will switch the fridge's power cord to the one with the Anderson connector. I like Andersons more the cig plugs.
Hope this is helpful and not to geeky.
i like your solution too. fun with relays!
The old 2370 putting in some work this morning . Got my wife to Reston Hospital for her shift last night without incident, though ATs will be going in the Tacoma ASAP. The HT stock tires were relatively drama free but nothing like the tires on the old 1st gen I gave to my brother. Man…. Tires everywhere! The 40, the taco! This will be an all day affair here.
