Power steering conversion help needed
Posted in another thread by Rezarf:
did some research today and found the pulley and bushing at Grainger (spent quite some time with their tech department) and they cross referenced the Martin Sprocket pulley and bushing and gave me their part numbers.
Pulley: #3x586
Cost: $21.64
Bushing: #3x573
Cost: $4.53
Might save you a few sheckels....
Update: The Cruiser is now home and almost complete. Muddy has other obligations this summer and can't finish the cruiser. He did fine work on the truck, but ran out of time.
My next step is the pulley for the pump. I'm going to try the Grainger pulley-will the above part numbers work on a saginaw from a Waggoneer?
The next step is shocks for the lift, then the aussie. Hopefully done soon.
Timber, just get a whole junk pump from a Volvo 240DL, I picked up one for $5. Press off the hub assembly with pulley and press it on the new/reman pump. The pulley is almost identical in width to the wide groove in the Toyota.
PinHead tipped me off on that one. Pulleys are kinda expensive, and if it is a press-on, you'll still need the hub.
GL
Ed
timbercruiser said:
Tried that-didn't fit. 1990 Volvo 240DL.
Sorry, should have added early-mid 80's 240DL, worked for me, but my pump is a press-on tapered shaft, no keyway.
GL
Ed
if its a 79, why not use a fj60 PS pump, it will bolt right up to the block, if you go that route and a mini box, I have a part # for the high presure hose, like $50.
Does the shaft have a keyway? If so you can get a pulley from any supply company...
the pulley i am currently using is mcmaster part # 6245k912
it is not an ideal solution, as it is not a particularly stout unit, and it uses a set screw to locate itself to the shaft, whereas our pumps are meant to have a nut on the end of the shaft. I have been running this style pulley for a number of years with no problems though, just tightened the set screw into the threads on the pump shaft.
Bailey, he (Timbercruiser) has a press-on shaft on the pump. I'm going to the Vulva boneyard tomorrow to see if I can score another junk pump for cheeps.;)
Ed
CruisinGA said:
My fault, not paying close enough attention...
dude, just ditch the press on shaft pump...
pumps are cheap and plentiful...
I scored a Vulva junk pump and pressed off the hub and pulley that I am sending TimberCruiser tomorrow. The pump also came with (as did mine) a bracket that spaces out the pump perfectly, eliminating the stack O' washers and stiffens the pump mount.
Ed
The only thing I do not like about the Volvo pulleys that I've seen/owned is the OD. I think the diameter reduces the performace of the pump. I do like the fact that you can use the Toyota width belt. Ford has a press on pulley that uses a belt that is wider than the GM pulley and will not bottom in the Factory pulleys. D5AZ3A733A - hard to find, but smaller in diameter and works well.
Thanks, Degnol. Poser's right, score a few more, there seems to be a demand for them.
As for enough pressure, I'm currently running 33x10.5, so a slower pump shouldn't be an issue.
