Power steering conversion help needed
Ok, lemme start by asking not to get flamed about this. I am a Jeep guy (GASP) and am doing this work for a friend. I searched here and found many posts about the conversion but so far none met my needs. Maybe i'm not using the correct yota terminology.
Anyway, I am working on a 78 or 79 fj40 with the stock 6 cylinder.
I have the power steering gear, all the needed brackets and the saginaw box and pulley. What I need to know is what you guys have done for the high pressure line. Is there a conversion line I can order or is there one from another application?
This guy dropped a bunch of parts off with the 40 and included with this were 2 braided lines and neither one will hook to the gear or the pump the way they sit right now...so no clue what those are for.
Any help would be great, even if it's a pointer to a different post. I just don't want this favor to become something I regret doing for this guy.:doh:
Thanks.
are you a friend working out of the house or at a shop?
well i don't know much about the power steering conv specs or anything btu i do know
the SEARCH function works. And i also know the TECH section works. ANd i also know that you can get custom made hoses for your setup at Napa auto parts, they will custom make them.
are you running a sag box with a sag pump? if so there are so many articles and writeups on this its not even funny.
goodluck you seem liek a nice guy doing this for a friend.
with that said. Keep Cruisin'!
Welcome.
I have not found an "off the shelf" hose that works for the Saginaw conversion on a 40 series.
I have a custom hose made at a hydro shop or larger auto parts places.
Good luck!
-Steve
Well gee okie...thanks for letting me know the search function works and thanks for all the other GREAT info you offered.:censor: Seems like even the yota word has their pirate4x4 guys.
Now for the other post, I am using what looks like a stock style yota steering gear. I live in Sault Sainte Marie Michigan so there are no hose makers around here.
I'm a high school auto shop teacher doing this for a friend. NAPA here does not make hoses.
HAHAHA....didn't realize that was a link at first so I was like...ok went outside and yelled for merle and he didn't answer.
Thanks for the link.
Do you have a pick and pull if you do get a hose that matches the pump and the box ie O ring or flared end, if you have a farm implement store they can take the ends of the PS hose cut them off and use a hose at the right length with some compression fittings on each end the size of the tube from the automotive hose another option is a place that does hydralic rams and hoses. Much cheaper than automotive Hope this helps, Larry
hey Poser i was under the impression that NAPA will custom make the hose end for you application.
hmm?
Not up here in the sticks....talked to them today and they said no.
But farm implement places we have tons of. Never thought of that. That may work.:beer:
The power steering hoses are usually up in the air. Several different types of power steering gears and pumps can be mounted different ways. I gave have up on custom made hoses after one blew up on the trail. Now I just go to the wrecking yard and find one that looks like it will fit and use it. I also always carry a spare, after the custom one blew.
At the top of this page is a "Techinical Links" hot link. Click on it and it will open up a page that has dozens of topics. One of them is 'power steering'. That has several good write ups on what you are tryng to do.
The fitting size is the same for the pump as it is for the box. I used two 90* fittings(Flared) and had them make me a hose. About $20. GL
Ed
It seems that not many people are using what I am using. I have what appears to be a stock power steering gear from some sort of a FJ. It looks just like the non-power one in the 40 right now except it is power. Most of the write ups are using saginaw boxes and replacing all the steering stuff in the process. I'll have to get pics so you guys can see what I am talking about...I know it's hard to understand without pictures.
Bear with me...I'm just new to this toyota stuff. If I can put a fuel injected 383 stroker in a jeep YJ and a 454 big block in a jeep CJ7 then I can do this....but everything is all upside down and backwards on a yota.:)
You mean everthing upside down and backwards on a Jeep, right??:D ;p
Doesn't matter. It will all work out in the end.
MuddyPaws is a good guy. His students are doing the work (pray for me!) and he is supervising. It's a saginaw pump and mini box.
The lift is on and the Aussie should be there this week. I can't wait to wheel it! It'll be a whole new truck!
Sounds like you have a minitruck/4Runner box. Is it push-pull? If you have a GM pump and a Minitruck box, the same fitting is used on Both the pump and the box. The return line is a bastard size, and hopefully you got that with the steering box, it is just a screwed in nipple. I will have one made up and mail it to you if necessary. I think mine was about $20-22. Yes, pics would help.
Ed
Pulley
This is where I ordered my Pulley. I have a GM pump with the Mini box.
Orion Manufacturing ph# 1 908 558 1600
Ask for Ladis
Martin Part #s
Pulley-- 1-b-50-sds
Bushing-- sds 3/4
Even though I ordered it last week, I can't remember the cost. Something like $36 and $15. They ship fron NJ.
If you have a press-on style(as opposed to a keyed shaft) GM pump, go to a salvage yard and buy the whole pump off an 80's Volvo 240 DL. I paid $5 for the whole thing. The pulley is the same metric width as the larger Toyo belt. Press off the pulley assembly and use it on your new pump.
GL
Ed
