Powder coating question
Keller, TX
I have a question for the guys/gals out there that are real familiar with powder coating...
since powdercoating is so durable, what is preventing people from powdercoating the body panels on the fj?
seems like the only thing major I've seen powder coated before is the frames of various cars/trucks
is there something that prevents this from being a good idea? just curious because I was contemplating doing that whenever I get to the point of having the Bruiser Cruiser ready for paint.
Thanks in advance:beer:
Have you seen my build thread???
You'll see I powdercoated just about everything including the tub. No chance of chips because all I did was the powdercoat primer stage and it is very very durable yet not a whole bunch thicker than regular paint. In fact the tac welds were still very visable ;)
around here, you'd have to find a place with a big enough booth to handle it
Cornbread said:
My local powdercoater told me that the heat can warp some of the body panels when they bake it. I figured that was a pretty good reason.
Did he actually get to see this landcruiser nonetheless know what one is..
The heat from the oven is not going to warp 16 guage steel :rolleyes:
Coolerman said:
One reason would be touching up any chips or scratches. Though you can use a portable infrared heater to do spot repairs.
Be the first to try it!
yea u got it . it will fade mor ethan paint. if you get a dent of scratch you would have to do the whole piece and it might no tmatch the color because of fading.
but for a rock crawler that you beat im sure it would be fine.
agreed maybe on a newer 80s car but not an old cruiser.
additionally, the time it takes to bring a cruiser up to 400F would cost too much in assembly. that is a lot of energy to blow on just heating up body panels.
many cars today arent made entirely out of steel. you would be looking for trouble putting a plastic bumper cover into a powder coat oven. so rather than powdercoat a body and then have to match the paint which would fade at different rates, save some money in manufacturing and just use paint.
i am planning on powdercoating the body and frame on the two restos i am doing. should be interesting.
Powder coat paint that is formulated for exposure to UV has excellent resistance to fading and will keep its original luster for years. Powder coat paint that is not formulated for UV resistance should not be used where it will have consistent exposure to the sun, as it will fade and possible chalk over time. A lot of powder coat houses let you pick the powder you want without asking you what the application is. Here in Tucson, I have used three PC houses and only Anderson Paint asked whether or not the part would be used outside with consistent exposure to the sun. They were very helpful in picking a powder that had the right color and properties for the application. As far as doing large items like the body panels, all the PC houses in Tucson that I have used have roll in ovens that are large enough to do 3 or 4 complete sets of body panels for an FJ40 at the same time. They also have continuous track ovens that pass the pieces on an overhead track through a ~40 foot oven that is large enough to pass most of the body panels. Most ovens run at 400-450 degrees and the more mass the part being powder coated has, the longer it needs to be cooked. I do not think warpage is an issue for body panels. There are powder coats available that are far more scratch resistant than auto paint including the likes of Emron automotive paint (Cardinal Black Hammer for one). There is a reason why most bumpers are factory powder coated as opposed to spray painted. DURABILITY
Edit: The issues that would be a drawback are that all the panels needs to be raw/clean metal which would require media blasting to remove the paint and rust without distorting or warping the panels. The other drawback is the cost. I think it would run 3-4 thousand dollars or more to media blast and powder coat an entire body. I've had estimates in the range of $500 to $750 to just do the frame. Maybe you can do it for less money in your area.
nick said:
The TLC Icon is totally powder coated.
Check it out...tlcicon.com
Yes it is!! Cool
Make sure if you do a metalic that it is silica or a clear coat over to prevent fading and discoloration.
Toyo FJ40 said:
There was a 40 on Ebay about a year ago with the tub, doors and roof sides powder coated smurf blue. It had an interior from a BMW 4x4 and went for $58,000.
Kevin
I think I remember that one..
It had a V6 in it right??
MOUNTAINCRUISER said:
I veered away from powdercoating my tub, and instead just chose to soda blast and paint. Still in progress but I was also told that it would warp the tub from the heat.
Once again, you were misinformed..
The heat will not warp the 16 gauge steel that a 40 is made from.....
