kling-on said:CNT isn't a option...'just do it cause it's just as hard to not do it Mmm.
Its not that hard to do anyhow.
Ya I've done em... I just convinced myself I needed the piñon angle low to clear the oilpan ... Now I see it's too low ... So time to redo it again LOL
... SO for now I'm putting a 4 * shim in and removing one leaf so it'll lower the front down some so I can wheel it .... this "SHOULD" put me back to stock pinon and caster .... I'll build a new axle later .... I'll work on pic tomarrowmy motor is a 1 -1 1/2 too low AND too far back ..... I run a Ujoint top and bottom to clear the tranny pan ... my biggest problem was I ASSUMED the 0* ruff stuff perches were the same as Stock IE 0* change .. they are just 0* amd my pinon dosnt point up at ALL so my caster is great like I did a CNT but my pinon binds up on flat ground... SO for now I'm putting a 4 * shim in and removing one leaf so it'll lower the front down some so I can wheel it .... this "SHOULD" put me back to stock pinon and caster .... I'll build a new axle later .... I'll work on pic tomarrow
So at the stock pinion angle, it shouldnt bind right?
Whats the stock pinion, ~10* pointed up? Yours is at 0*... yah that makes more sense that it would bind.....
So if I weld perches in while keeping the stock pinion angle, it shouldnt bind, and be close enough to paralell to not have any issues with vibrations?
My main concern is caster... I dont want to die yet.
Would a small CnT to get ~4* caster be a bad thing in this configuration?
This truck it's a fail ... Patches it's a win![]()
