It seems you took my opinion pretty hard, when you assumed I was so "behind the times" that I wouldn't use a seat belt or synthetic oil, and that my vehicle is in serious neglect.Are we on the same thread reading the same things? "looks like you took some criticism pretty hard"???? I'm open to criticism, input, feedback, opinions. All will be taken into consideration both good and bad. Not sure where you think I took offense to anything or took it pretty hard. I'm fine with all of what has been said. Bring on the rest, the more opinions/criticism, the more informed decision I'll be able to make about where this will go from here.
For the filter element, as I stated in my reply to your previous post. This is just talk at this point. Nothing has been designed, nothing has been put on paper.
As far as replacing yoru filter every 10 years. That is a little out there. It's a cheap part that is meant to be replaced as a wear and tear item. That's like if you were to say you would replace your oil filter every 10 years. That's just ridiculous. Replacement interval would also depend on the type of driving you do, what sort of environments you're driving in, weather conditions, etc... If you're driving through construction sites and mud pits all the time where there's an excess amount of debris floating around in the air, then you'd obvously replace your filter in shorter intervals. If you're just driving in your neighborhood on clean streets, the filter will last longer. I know you're trying to make a point, but if you're really recommending to that people should replace their FZJ80 filters every 10 years... yikes. Personally I wouldn't risk the health of my motor on a 10yr old filter. To each his own I guess.
Hopefully after it has been mentioned numerous times in this thread, you are picking up that the OEM filter is a high quality washable/reuseable filter, like I said in my last post... FYI, I don't know the part number, but it is the current standard OEM filter, there is no other option from Toyota.
truck is almost exclusively a pavement pounder. Comparing filters there is not a lot of difference, mine is noticably dirtier but it's a small degree of difference.
