Performance air filter?
NKP Garage
Forever Learning
Texas
Website
www.youtube.com
So we all know that the K&N filter that is available for the Land Cruisers & LX450's is a joke. It has less surface area than the stock filter, it's smaller, and you're better off with the OEM Toyota filter.
My quesiton to you guys is, would you want a performance filter that is properly designed? One that is has as much or more surface area than the stock filter, is washable & reusable and also comes with a lifetime warranty? I have been tossing around the idea to have them manufactured. They'd be manufactured by the same facilities that manufacture K&N (and other brand) filters. We could make them in a dry filter, or in an oiled filter.
If there's enough interest to sell at least 30 or 40 in the first batch I'll go ahead and get things rolling to get the first 100 made.
Let me know what ya'll think.
Dry and washable. But, then again, that would be an OEM filter unless there was a notable performance increase and competitive price point.
My first question, as some one that doesn't know much/anything about air filter technology, would be why do I need this? Is there any evidence that the OEM filter starves the engine for air? From looking at the already large size of the OEM filter, would there really be any benefit in running a performance filter? The surface area of the stock filter looks huge (anyone ever open one up and measure?). If you could design a filter that would flow a higher volume of air more easily than the OEM filter, without compromising the filtering ability and durability of it I might be interested, but only if it was also proven to increase engine power. Otherwise, what is the benefit to me/my truck?
:cheers:
I'd get one if it fits what spdWAVER1 was saying "notable performance increase and competitive price point"...
The main two benefits from my point of view would be longevity and flow. We can definitely make a filter that will flow much better than stock, and the fact that it will be reusable, washable and be warrantied for life is a big plus over stock. The stock filter is a disposable item that you can wash out maybe one or two times at most.
As far as power gains, we can do a dyno comparison back to back. With a naturally aspirated vehicle power gains will be minimal, maybe around 5-8hp. On supercharged or turbo charged vehicles power gains should be more. But all of the power gain talk is just speculation until we get one on the dyno.
It is an awesome idea to think we'd have a $40-$80 drop in product that improves performance even a tiny bit, but I echo the sentiments of the above posters. These stock air filters are massive for an appropriate reason. In many markets, these trucks are used in dusty, sandy, off-road conditions for their entire lives and come appropriately equipped with a high surface area filter.
The largest criticism of the K&N is that they tend to increase airflow by filtering less. If a drop in filter were redesigned, what would be different to ensure that it filtered as well as OEM and increased airflow?
I highly doubt you're going to get much more flow out of a performance filter. The OEM filter is absolutely huge, so while you may have a better flowing material/design, the large filter area means that any gains there are minimized.
And of course typically a better flowing filter means a worse filtering filter.....
Longevity is not really an issue for these filters. The OEM filters are extremely well constructed, and they are cheap enough that even if you buy 2 or 3 over the life of the engine it's a drop in the bucket. They are designed to be washed many times and will hold up to it. They are not a "disposable item that you can wash out maybe one or two times at most."
Good thinking, but I think you're looking at replacing a part that doesn't need to be replaced. :meh:
Warrantied against what? The filter failing?
So you get a big hole in the filter via media separation, the engine inhales a bunch of dust, and your engine is ruined - then what?
Peanuts to pesos says that the only thing the warranty would cover is the replacement cost of the filter.
No offense, but I'll stick to the OEM filters - they're not that expensive.
I have to concur. I'd be extremely leery of installing a filter that may have less filtering ability than the stock OEM, or another proven design that's already in service. I have a Donaldson on my truck, it's a swirl-flow proven design that's installed on commercial diesels, usually. It's been around for decades and does an excellent job.
I stay away from K&N for the simple reason that they allow way too much dirt into the engine. One of the reasons I bought a landcruiser was because of longevity. A poor filter will remove that advantage, rather quickly.
You just described a K&N filter perfectly.
I'm very impressed with the factory filter setup. The cyclonic housing and huge filter area combine to do a great job of handling huge amounts of dust. Even in the dusty southwest environment where mine is operated it takes a very long time before significant restriction is seen. My guess is in more moist environments, it wouldn't need to be cleaned before 60K-100K miles. It's rated for 10 cleanings, so pretty much a lifetime filter.
So can anyone point me to any articles online of vehicle engines that have prematurely failed because the owner was using a K&N filter? I've read the article comparing the various filters' performance, including the K&N...but would be curious to read of any engine damage directly attributed to the use of a K&N filter.
If such events have occured and are credible, you would figure that K&N would be bleeding money from lawsuits.
Nope, it's one of those things that are almost imposable to prove. That is why they can make the claims that they do.
The amount of dust allowed through is relatively easy to show and there are several sites that document this. Higher dust in the intake will cause higher wear rate, reducing engine life.
There were some studies conducted a number of years ago, by some companies that use offroad equipment, like big construction machinery, etc. These were earthmovers, tractors, that sort of thing. They did exhaustive studies of the differences in engine oil analysis using different filters. It was determined that K&N allowed more grit inside the engine, hastening the wear. This showed up in the oil as elevated readings of the metals the engine is made of. This was not the case when the OEM factory filters were used.
These were high-dust environments, not your typical day-to-day automotive use. However, since we often take our cruisers out into dusty areas, I think the analogy holds.
I wouldn't be afraid to use a K&N around town, but I'd stay away from it for offroad use.
I'm sure if you spend some time with a search engine, you can probably locate these studies.
Lacruiser...I just read that one with the earth movers. Interesting...they had to shut down the trial after only 4 weeks due to the oil analysis numbers they were getting indicating higher wear. They weren't using K&N filters, but an oil on cotton filter similar in concept to K&N. Their OEM paper filters ont hose trucks cost something like $500/ea!
What time frame are we talking to get this done? I am ready for a filter now because my PO has a K&N filter on it. He "said" it was never off road and when I went to test drive he did not know how to use the 4LO lever at all. I want a different filter because of all the negativity I have heard about the K&N's.
I've washed my stock filter at least 2 or 3 times and it's held up just fine. In fact, I've been pretty impressed with it. I'm sure it will still last a few more hard years and more washings no problem.
On my last summer trip where I spent about a week in the desert driving almost nothing but dirt and gravel roads, I was absolutely amazed at how much dust and dirt I knocked out of that filter. I was horrified to think about what a lesser filter could have subjected my engine too. And I've vowed never to run anything less than the stock filter again. Granted I was following other vehicles part of the time, which probably contributed to my dust intake, but you never know what situation you're going to find yourself in unless you're driving a mall cruiser.
That said, for street only rig, this may not that big of a deal. I have noticed some slight gains with K&N filters on my other rigs in the past. And of course they sound nice. To me, an open air filter makes a much nicer sound than any exhaust mod. But I hate the oiled versions and they are a real pain to clean.
To me, for an 80, I think one could expect decent, allbeit slight slight, gains by installing a safari type snorkle and still retain the protection of the stock filter...plus have the added option of a dust collector when you really need it.
I think some of you guys are missing a few important points.
* We are not looking to make a "replica" of the K&N filter that is available for Land Cruisers. The filter that K&N makes for these trucks is smaller than stock, has less surface area, and as far as I can see, probably is more restrictive than stock due to it's size.
* We are not trying to make a stock replacement that has no value add other than a lifetime warranty, if we were to make a filter that is just like stock, performs like stock, and does nothing more, then there's really no point, just stick with the stock filter.
* IF we do make a filter, it won't be a cheaply made filter that will have holes through it after a small amount of use and a couple of washes, so those comments about engine failure, not sure what you've been using or how you cleaned your filters that put holes in them, but that will not be the case here. The warranty is for the filter, if you wash it so many times that it starts to deteriorate, we'll replace it. The warranty will obviously not cover your engine from the installers negligence.
The main point of this IF we do go through with it would be the items I listed in my last post. To manufacture a filter that flows better than the stock filter, has as much or more surface area, and will last longer. If there's a market for it and you guys are up for it then I can get the ball rolling for the design work. We can also do tests afterwards to show how much dust/dirt gets through the filter compared to stock and how much it flows compared to stock. That will obviously be later down the road when the first units get made.
I'm well aware that the stock filter does it's job just fine, but I also think that there is room for improvement in both the stock air box and the stock filter.
