This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
I found my FSM for the 97 4Runner on eBay for maybe $60. I don't think it was ever opened. I'd say it's quite the comprehensive document!
Ditto! Mine was opened but its in decent shape. I keep it in anticipation of a 3.4 transplant (never throw anything away).
@pappy if you want to borrow this let me know, if the 97 is relevant.
- 88 4Runner soul saver pile of junk
- 94 P/U heart of gold pile of junk
- 90 4Runner dog kennel pile
- 84 P/U blue meanie angry pile
- 85 FJ60 V8 pile of smiles
High Desert Cruisers of New Mexico, established 1998
photosynthesizing
Moderator
... if you want to borrow this let me know, if the 97 is relevant.
I just ordered the 1998 two volume set for the 4Runner (reprint, actually). The problem with the 1997 is the wiring is all wrong. For some reason Toyota change the harness 1997 to 1998. Even the OBDII connector was wired different, something I thought would be consistent.
Your 1985 book is way too pretty. Mine is beat up.
1969 FJ40L aka TOROTE: 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB. Suffering from pre-sellers remorse.
1985 4Runner (RZN60LV ). 3RZ supercharged, R151F with dual 23-spline TCs, lifted, locked, 32" training wheels .
2025 Tacoma TRD Off-Road , 285/70-17, Dirtbox camper/canopy.
I've seen many people go to the desert. They never come back the same. It's best to just stay away ... and leave more room for me.
"Desperate times call for bending and breaking s***." ~Ashfaq Ali
photosynthesizing
Moderator
Bling, bling, bling. T100 oil pan. 4Runner and Tacoma are front sump and would hit my front diff. T100 pan is rear sump.
photosynthesizing
Moderator
4Runner is running. The only observation I'm making at this time is the LCE camshaft is not what I was hoping for. Even though it's supposed to be a street cam, it does have a noticeable lope at idle, and it pulls less vacuum than my DOA C270. It does pretty good on the freeway, but is not as friendly around town as I would like.
Congrats! Even though the new cam is not quite all you were expecting, at least the truck is running while you work on the new powerplant!
- '93 FZJ80, lifted, locked, Slee'd and Hanna'd
- '09 Hybrid Camry
- '00 Celica GT
- '21 Hybrid RAV4
- '12 Tundra Crewmax 4X4 5.7LV8
photosynthesizing
Moderator
Yep. I took the truck out to 9-Mile Hill. It does fine on the freeway, and is very happy above 3600 rpm. It will do just dandy for now. I will burn this tank off, then readjust the valves.
photosynthesizing
Moderator
A step in the right direction.
photosynthesizing
Moderator
Boy this has been a slow process. A 2003 Tacoma showed up at the u-pull yesterday, so today I went for a look. 2RZ. But, it had the three pulleys I needed, plus a few little things. It also had the power steering pulley I needed, but I forgot my puller and couldn't get it off. Saturday I will go get it along with the AC compressor.
I also pulled the starter, but it wasn't a Denso, so I left it. Those things are a boich to get out.
Both crank accessory pulleys, and the fan/water pump pulley.
'97 4Runner SR5 with some toys SOLD
'19 F350 4x4 XLT, '05 Avalon Limited
'97 Holiday Rambler 5th Wheel
"Why do it right, when you can do it yourself?"
I agree with Chompers - one step at a time. You've been here before with your 2-FE build for the 40, and you've already got the big pieces. Now just to find all the little bits to make it happen.
- '09 Hybrid Camry
- '00 Celica GT
- '21 Hybrid RAV4
photosynthesizing
Moderator
I'm just glad I found these at the u-pull. They were $11 each instead of the stupid money Toyota wanted.
photosynthesizing
Moderator
A little boneyard visit today.
They had a T100 with a 3RZ. Even though I had already bought the oil pan stuff from Toyota, I decided I wasn't going to let this stuff get crushed. But ... long story short ... after getting out all the bolts, and starting to remove the cross-member so it would drop down ... it had a f'n hole in the pan with a goofy rubber plug. I left it.
They also had a 2001 Taco 2RZ that dropped yesterday. I decided to grab the alternator. 1995-2000 was 70A, and 2000+ was 80A. Of course I had the brackets and adjuster for the 70A. The 80A fit the lower 70A bracket, but the 70A adjuster was all wrong. I tried to get the adjuster out of the Taco, but I couldn't get the bolt to crack loose with one hand. The other hand was holding up the crinkled hood. I'm going back tomorrow with bigger tools and grab both the lower mount and the adjuster.
Oh, I forgot. It was a Denso reman which is why I decided to grab it. After getting the alternator home I popped off the back cover and pulled out the brushes to see how worn they were. I think the pic says it all. I scored a nice Denso! Now I just need to make it fit.
photosynthesizing
Moderator
Much better. 80A alternator on the engine.
Looks good - more progress!
- '09 Hybrid Camry
- '00 Celica GT
- '21 Hybrid RAV4
photosynthesizing
Moderator
Picked up new brushes for the alternator. New length is 10mm. Currently length is 6.6mm. Installed new set. Will stash old set in the oh-crap box.
photosynthesizing
Moderator
A solution in search of a problem?
Well, probably not. I have four relays and two aux fuse blocks under the hood. I need to add one more relay. Once I get the engine out I'm going to redo the non-factory wiring. The switched fuse block, and all the relays, will go into this.
Wait, what? Pull the new engine back out? Damn retirees gets to do this s*** for fun 'cause they got all the time in the world.
~Ali~
'96 FZJ80 - Dobinsons 3" springs/Ironman 4x4 foam cell PRO shocks/Whiteline F&R sway bars/315s/locked/4.56s/aired/wired / Witt's End Turbo making the 80 great again.
'03 4Runner Sport V8 - 2" lift/Bilstein shocks/Bilstein 6112 coil overs/ICON rear springs/NWTI front+rear bumper/aired/wired
'97 4Runner SR5 (daughter's) - springs from 5th gen, mildly lifted, more to come
photosynthesizing
Moderator
Technically, the engine is 5 years old. It's the cylinder head that I had to replace this last winter. But ya, that 3RZ is going to be sweet.
Ahhh, gotcha. I thought you'd swapped this engine out already.
~Ali~
photosynthesizing
Moderator
A little wrinkle. From Marlin Crawler:
"Jon, we are out of the 2TR Bellhousing kit. It will be 3-4 months before we receive more."
