Overheating is killing me!
I am curious, Did filling the cooling system solve the problem ?
No, thermostat ha
No, thermostat hasn't been replaced yet. Gonna search for one tomorrow.
Did filling the cooling system solve the problem? Well... I let the engine cool down, then fill up the system again. SO of course it's cool then. But after a few kilometers the problem returns.
While these are all great things to suggest and/or do, my point was that the HG is probably compromised at this stage due to age and overheating. I'd hate for him to have it completely fail in an area that he can't get good mechanic/machinist assistance.
Maybe, maybe not. Lots of previous discussion here on preventative HG R&R. Unless one has plenty of money to throw at potential problems, the consensus seems to be wait until you're sure. Certainly, under the circumstances, it would be worth looking into, but not sure about availability of test kits, etc like we do it here. And $$ seems to be a factor. Hard to justify doing the HG when it's uncertain that's the problem.
Then there's that flaky radiator. Wouldn't be much point in a new HG, is the radiator is still puking out coolant. You're still neck deep in probable compromise. If it is the HG, the radiator needs fixed anyway. If it is just the radiator, then he's done and good to go.
Re antifreeze...Water actually is better at carrying heat away, which is why they caution against running high % of antifreeze in warm environments. In Colombia, under most conditions freezing is never going to be an issue (they do have mountains, but doubt problems with frost right now.) If you're leaking constantly under those conditions, no point in putting in anything but water.
Precisely my thoughts... Like I said, I tried to see signs of a leaking HG this morning, but didn't see any. Could be that the whole engine first has to be hot to show the symptoms, but...
Anyway, tomorrow we are going to search for a new fan clutch and thermostat, and try that first. This city has some very steep climbs, so it's a good testing ground. And maybe I can find a good used radiator over here. I'll keep you guys posted.
By the way, how do I know my water pump works well enough? It is not leaking.
If it spins freely without any binding or wobbling and its not leaking then its probably OK. You can pull the pump off to properly inspect the turbine, but you need to have a new seal ready to go to put it back together. In a pinch you can seal it up with rtv gasket sealant, but that would only be a temporary solution to get you moving until you can get a proper seal.
Fan clutch is vital. When mine went out I started overheating in 75 degree (Fahrenheit) weather as soon as I turned on the A/C.
Didn't know that a fan clutch could make such a difference... Like I said earlier, it doesn't leak, but it wobbles a little bit. And I have stuff with me to cut my own gaskets, so that's no problem.
Now we're getting somewhere.
You need to figure out EXACTLY what is wobbling: Water pump shaft from inside the water pump itself? Fan clutch wobbling on its shaft? Etc.
Now get off the computer and start investigating. :flipoff2:
We actually soup them up for max performance here in the desert. The stock blue hubs that are currently available thru dealerships only have either 4000 or 7000 CST rated silicone. We upgrade to 20,000 to 25,000 to max out the power of the fan. If yours is getting tired, then it could well be the problem. On the other hand, you know that you already have a compromised radiator, and if it is getting clogged up any more than the tubes that are already bypassed, then that is a major suspect. Swapping in a used one may or may not make any difference, as it could also be compromised. I swapped in a new Koyo 1918A, which was identical to the OEM original that I took out. The old one had only run Toyota Red, and it had been flushed several times over the years, but as soon as I replaced it, TA-DA!! All cooling issues disappeared. I can now run up the mountains, at speed, with the A/C running, and it never gets over about 203 degrees. Very acceptable, considering I wheel the desert in the summer, and I really stay on top of my engine temps. John
Re the water pump, sure it can fail. Historically, water pump failures have not been a common problem for the 1FZ. Unless it shows definite signs of failure (leaking, seepage around the shaft...) most likely it is not the issue.
Bad Fan clutch example
Also hose off the fins on the evap core and radiator from top to bottom with a gentle stream. Could be mud, bugs, etc. in there, youd be surprised how much dirt builds up and that can reduce cooling efficiency.
Shaft is not wobbling. Every few seconds you see the ventilator wobble, while the shaft stays straight. Already investigated that :-)
Thing is clean :meh: And the video: no, it's not that bad, haha!
So if it's not wobbling and not leaking, small chance it is not good anymore...?
you do not need to cut gaskets for a fan clutch - just make sure you do not damage the rubber ring which is unobtanium (it can be difficult to go back in upon reassembly, so put the ring in the freezer for a little bit before re-installing)
have you checked whether the fan clutch comes on with the truck running at any time before it gets too hot ?
When I start it, the fan is already working, but I can stop it with a rag when very hot.
Thanx for the info. With all this new info I am starting to get a little more hope that there will come a moment that we just can enjoy our travels, instead of continuesly having problems. After one Hilux and two Land Cruisers I'm almost starting to think that I'd better change this one for a Landrover!
You didn't just say that.....
