Amigos, before I'm buying too many new parts, please hear me out. Professional advice is more then welcome.
Bought the '97 Lexus LX450 for our extended trip through South America. The cooling system leaked a little bit, really not much, and the temperature of the cooling system was fine. We did the guyanese jungle and savannah, in the tropical heat, the long stretch of asphalt to Brazil, after that the mountains up to Venezuela, and after that the Gran Sabana, which was some fast climbing. And after that again long stretches of asphalt through hills and low mountains. We reached speeds up to 140 kms/h (=almost 90 mph).
No overheating problems at all. While I had no ventilator shroud at that moment and used my aircon.
But halfway Venezuela the troubles began, supposedly because of a leaking hose and a corroded alu pipe. We replaced the stuff and thought everything would be okay. It wasn't.
After that we found a new shroud in Colombia, replaced the radiator cap with a new Toyota one, the system has no leaks, the fan turns when stationary and when revving while standing still, although the fan clutch feels weak, the thermostat opens when the engine is warm enough, we don't use the aircon, AND STILL THE STUPID THING OVERHEATS!!!
When driving on flat roads, it overheats after a while, when I have to accelarate fast, it heats up very fast, and when we have to take a slope, steep or not steep, it overheats, even when we ascend it with 10 kms per hour...
It is not just the gauge, because the coolant starts boiling.
So could it be the radiator? It misses a few vertical "ribs", although it is the same one as which we did the 140 km/h with and took the steep hills.
Could it just be the fan clutch? It feels weak, but the ventilator turns.
Could it be the water pump? How do I now if it functions well enough?
Like I said, professional advise would be more then welcome, because, with these problems, driving these awesome mountains is no fun...
Thanx in advance!
Thanx in advance!
