Overheating is killing me!
I finally got to talk to a few very experienced mechanics
Highly experienced mechs actually said, red and green coolant clogged the radiator?
If the radiator was clogged it was most likely due to stop leak of some sort, not from mixing coolant.
They knew nothing of the mixed coolant. That came from the radiator shop.
This morning we started a spare parts hunting party through the city. Believe it or not, but within two hours we found a brand new fan clutch, a brand new radiator and belts for USD 400, labor included, so I even don't have to do it myself. I remembered (leaking brains) that I replaced the thermostat in Venezuela, so we leave that for now.
So I'm a happy person!
I'll keep you guys posted if this will sove the problem.
Sounds like progress....although I'd keep in mind the T-stat if any issues remains. I assume it's in there correctly, but you may want to verify that if you're not certain and everything isn't cleared up by this work.
Yeah, I'll keep that in mind. I thought it be wise to wait till all this stuff is stuffed under the hood. If the problems are not gone, the thermostat goes out to see if that helps.
You have 2 problems you know about, a bad radiator and a bad fan clutch. While you may not want to hear it, you should replace them rather then speculating on the internet about other problems. Since thermostats are cheap, you should replace that too.
Water pumps rarely go bad, and when they do, they leak out the weep hole. If yours leaks out the weep hole, replace it too.
Any chance you got mud in the fins of the radiator?
Regarding the head gasket-it is a known weak spot, and is made worse by overheating, so I would fix your problems now before they get much more expensive. A radiator, fan clutch and thermostat is say $750 in parts. A new head gasket with labor and parts will be $3000, and you'll still have to fix your cooling issues.
Three posts above this one I just told that I already bought the radiator and fan clutch :D
But what should have been 2 hours in a shop for changing the radiator and fan clutch (price was including labor, so why do it myself in a busy street?) became twelve hours full of frustrations! There was no radiator for this model and also not with cooler for automatic available, so it didn't fit at the lower hose connection. End of the story, after a lot of troubles, was that they made a custom underside of aluminum.
But the radiator was really neccesary! Approximately 60% of the vertical "tubes" were clogged! I couldn't blow through it. And I can hear the difference between the old and new fan clutch. When I accelerate fast now, I really hear the fan, which wasn't the case with the old one. When I turn the old one, I feel strange "clicks" in it.
Sounds like good news at the end of a lot of frustration. I was sorta wandering of they'd have a radiator set up for the auto, but I guess you were able to figure out something. After being through similar issues last year -- without the great adventure part -- I know what a relief this must be.:beer::beer:
glad to hear it's looking better. Yup, they do tend to clog up.
From what I measured on mine, the ATF is usually quite a bit cooler than the (hot side at least) of the coolant so that you may not miss much the ATF cooler in the rad if it's not there.
TADAAAAAAAAAH!!! Problem solved! We just have had a few days in the mountains north of Bogota, Colombia, with very steep slopes (some of them I could only take in first gear (high), and even one rock bedding path in low. De truck really had to work and we used the aircon all day long, but the temp gauge didn't go up for one sec! Very happy with this. New problem though. Gearbox. But I'm going to make a new thread about that :-)
Anyway, thanx for all the input, guys! I love MUD!
