Overheating badly - need some help
I think this is one instance where there is a lot more to it than math. The fan has to evacuate the air behind the radiator so that the air can flow through it if not it is just going around. I have had a bad fan clutch and had issues at speed. They weren't as bad as sitting on hot pavement during the summer, but the truck still got too hot.
What? No, that's not at all true. Unless you're taking specifically about *disengagement*.
Except you are incorrect. The fan provides cooling at freeway speeds and will be at least partiLly engaged even at 50f. As another suggested, pull your fan and go drive on the greeway and watch the truck overheat.
I would jump in flush the system, then reverse flush the heater cores (F and R). Next replace your radiator, H20 pump, and thermostat. I would then do the LT fan clutch fluid (don't use 20K it's costing me about 1 -2 miles MPG when cold in town).
Are you losing coolant? is it going down? if so you probably have a HG problem .... which could have let go on your initial high temp signal when pulling the trailer up a hill. ALSO be aware that you wouldnt be the first person who also lost a rad concurrent with blowing the HG .... over pressure in your coolant system from a blow HG can destroy the upper rad tank seal to the rad core.
IF you are not seeing any coolant loss at all . ... and no bubbles in the overflow tank then you have other issues obviously and I would start at the thermostat and work from there. Generally a moderate speed of 50 mph on level ground without a trailer or load should see your temp lower --- even if the fan clutch was screwed and not working. As previously mentionned there is a lot of air pushing through the rad at speed than at idle ... which is why the fluid clutch is intended to disengage at highway speeds --- and normal temperatures.
Thanks ewillis, I had actually already referenced this thread a few times when getting ready to start into it.
I haven't been loosing coolant and tested the HG by checking the overflow tank for bubbles after heating it up and keeping engine at 3000 rpm for several minutes before I flushed the system. Again it only overheated when towing for a short period of time. What I am experiencing now is vastly different.
I'll post some photos tomorrow of the gasket material that I found floating in the coolant and see what I can do to solve the problem.
The fan clutch is almost certainly dead and will cause overheating on the freeway if bad. Try doing a fluid drain and refill with 15k-20k cst fluid. Pleanty of threads in how to do and will only cost $10-20. It is also likely your radiator is partially plugged.
This is what I figured is going on, but also think maybe air in the system? I have some oil on the way.
Air is easy to take care of. Take off and leave off rad cap. Turn on motor and let get up to operating temps so the thermostat opens. Put a wide mouth funnel in the rad opening and overfill with distilled. Hold in place till all bubbles come out. Have someone run the heater.
@landtank
When you have nothing better to do, walk me through this. Is it the forced air driving the fan? Is it the additional contribution of the fan being driven by the motor that makes the difference?
Thanks
Mo
With almost 50 years of playing with automobiles and tools.. I am in total agreement that a fan clutch can definitely cause overheating while moving down the road. Based on real life experience and being a perpetual student of automotive tech.
However any cooling system can benefit from a complete overhaul. Especially one in a 20+ year old vehicle!!
@landtank
Thanks
Mo
Moving air is all about restriction and that can be on either side of the fan.
Back in the day, 60's or earlier, the engine compartments were uncluttered and expansive allowing air to relatively move through the compartment un-restricted. So at highway speeds the pressure in front of the car was sufficient to move enough air threw the radiator to cool the engine or close to it.
Now look at our engine compartments, They are pretty stuffed and some add SCs, dual batteries, and who knows what in them. And then bumpers with stadium lights and winches. All of which is adding more restrictions on the intake and exhaust side of the radiator.
Fan clutches work by sensing the air temp of the air that has passed through the radiator. This temperature causes the clutch to adjust the drive to the fan to keep the engine running at an acceptable temperature. Once your thermostat is open the engine temp is controlled by the fan clutch as far as over heating is concerned.
As long as the fan is rotating it is moving air. I've never have seen a fan not rotating on a running engine so for all practical purposes they are always on. It comes down to how much drive is being transmitted which in turns is how much air is being moved.
So we need the clutch to be able to adequately sense the air temp at idle and then respond proportionately to the needs of the engine to control it's operating temperature through varying states of demand while compensating for addition heat from the AC and transmission and over coming air restrictions both on the intake and exhaust side of the equation.
all with out greatly impacting MPG.
Simple
Also, the fan clutch when cold has a fairly large rpm ratio compared to the engine. In simple terms think of a cold clutch's rpms as 1:10 vs the engine. As the clutch's spring heats up it opens the gate which allows silicon to move out into the rest of the clutch. As this occurs the warming clutch's rpm could be 1:5 vs the engine. Even at fully open/hot the fan clutch really only gets to maybe 4:5 vs engine rpms, maybe a little higher but only a mechanical fan w/o a fan clutch sees 1:1 rpm matching.
I would like to know one way or the other, so if I can get to it next week I'll try it.
Alright, as promised here are the photos of the thermostats side by side (oem vs old) and yes I did put the gasket on the OEM thermostat before installing it. Can anyone confirm the the flutter valve should be facing upwards?
Also attached is the gasket at the water pump to see if you guys think it is the same material I have found in the coolant itself. Does Toyota send them from factory with this type of gasket - looks like FIPG or did someone mess with this already before I got it. My guess is the latter given the non oem temperature valve.
Here is a photo of what I am guessing is the same gasket material in the coolant. How big are the coolant passages in the engine and could it have been clogged up by the gasket? How bout the radiator?
Alright, off to go and take the fan clutch out and water pump and replace with new.
Yea flutter valve goes to top, should be a gasket on water pump not fipg, if that came out of your rad then it prob is clogged , try flush but who knows if that will get it all out, new rad from Toyota cost me 330 year ago don't know price now but if was me I'd get one from @beno and live another 15 years with good maintenance on it
Beno is out of business until the end of July according to a recent auto response.
You can go here and get pretty competitive pricing. It shows MSRP until you pick a dealer location then you see the discounted pricing.
Toyota Land Cruiser 1997 4.5L Genuine RADIATOR ASSEMBLY - 1640066081
Or you can get a Koyo A1918 radiator for less than $200 shipped.
Yes, that red stuff plucked from your radiator is FIPG, specifically red silicone (Permatex)
Yes, it's possible it has clogged something somewhere. It also means that your water pump chewed it off and sent it through the system. Someone before you did a stupid thing with the sealant.
Yeah, I'm not very happy with whoever did it. It was likely done by a shop since it was a company vehicle before I got it from what I could tell on carfax years ago.
So, apart from the radiator getting blocked up, what else would be a likely place for it to get trapped and cause damage? Just trying to see how bad this could actually be. Despite the bad parts and bad repair job by the previous owner, the Landcruiser has run 100,000 miles since I've owned it without much trouble.
So I pulled the fan clutch and water pump today. Found the FIPG all around the pump and in the bolts holding it to the block along with a gasket that was there and was probably leaking at some point and this is how they fixed the leak instead of getting a new gasket. My lack of confidence that I can take a car to a mechanic and get a job done well is continually being re-inforced the more I do work myself. I know there are good mechanics out there but they seem hard to find. Alright, rant over.... here's what I found.
The old fan clutch looked to have cracks all through it. Not sure what brand it was. Here it is compared to the new one. Definitely didn't seem as robust as the AISIN.
Here is the water pump.
Again, the old pump wasn't as well made from what I can tell. The Aisin has more fan blades and better build quality. On the old you can see the gasket material from what looks like an old paper gasket as well as the FIPG.
Just for kicks, here are the instructions that came with the pump. Whoever installed the last one didn't follow instruction #3.
I wouldn't recommend taking your vehicle to the garage or mechanics that did the previous job on mine. Do it yourself.
