Here's the back story...97 LC original HG, radiator etc. overheated a little when towing a tent trailer up a pass when camping in June. I didn't have a obd2 reader so don't know the temps, but the needle on the dash (no raventai mod) started to budge upwards.
I hadn't changed the coolant in a little while so decided to refesh the cooling system a little with a coolant flush, new oem radiator hoses and new oem temperature valve a few days ago. I buttoned it back up, filled it with toyota red (that was what was there to begin with and decided to keep it) and turned it on. At idle it seemed to be hotter than I would expect (I since had bought a blue tooth obd2 scanner). It would creep up to 208 or so. I noticed the fan wasn't as vigorous as I had hoped but figured I'd give it a little drive and see if air going through the radiator would cool things down. Going at freeway speeds on flat surface temps just kept climbing and hit 230
. I had since already pulled over and stopped and poured water on the radiator. It slowly cooled down and I limped back home. It doesn't seem to be leaking from the hoses.
Fluid level seemed ok but it overfilled the overflow container when the coolant got so hot. Checked the level in the radiator and it was fine but noticed a red rubber gasket like material floating in the tank of the radiator. There looks to be similar gasket material at the water pump - not sure if that is oem or not.
Could that gasket material be clogging up a coolant passage if there is more in there causing sudden overheating issues? I read about "burping" the system but not sure if there is a specific method of doing so. I filled it up with coolant while running and there were initially a few bubbles but they stopped and fluid level seemed stable.
I plan to replace the fan clutch and water pump, but would those failing cause such drastic temps? I am afraid I may have a HG leak, but there wasn't evidence of HG failure before changing out the fluid.
Lastly is there a way to empty the coolant and re-use it since it is new or do I just have to dump it and re-place. If so how do you get it out without contaminating it with engine oil and dirt from the frame.
Thanks.
Thanks.
