So, I spent yesterday working on the landcruiser again. Drained the coolant and did another flush trying to isolate each component I could to flush it and see if there was any gasket material in the system causing this sudden severe overheating. I used a pvc pipe and hose connector to flush the radiator every way I could (thanks
@LandCruiserPhil for the idea in one of your posts).
I also took out the thermostat and tested it per FSM to make sure it worked since it was a new component I had put in when it started overheating. It tested fine.
Buttoned her back up and filled with distilled and she works great!!! Highest I saw while parked and reving the engine to 3500 for several minutes was 184.
So thinking back on on it, the only think I can figure is that a gasket blocked a passage or I was a retard mechanic and had installed the thermostat backwards
. I didn't find any gasket material with the flushing so its either still in there or I had already got it all out and screwed up. I am thinking the latter. Serves me right for flaming the mechanic that used FIPG on the water pump, which was obviously a short cut and wrong, but at least he put the thermostat in the correct orientation on install. Live and learn. I am pretty sure that this same thing is what was causing
@NLXTACY's rig to overheat too, but he didn't want to admit it and just made a big long thread beating around the issue
. Now to go and actually drive it to confirm it is working at freeway speeds etc, keep on flushing with distilled and convert over to green coolant.
Good news is I had been looking for a second landcruiser (my wife stole my 80 and uses it as her daily driver) and this whole overheating put some extra pressure on to find one since it is hard to function without a vehicle. I picked up a clean, non-modded out 97 lx with good interior, 1 owner and 198,000 without lockers for the wife to drive and I get the landcruiser back
. Just hope the HG on the landcruiser didn't get toasted with my dumb mistake
. And yeah, I'll still be giving you a call Beno, I now have a new rig to baseline and get up to snuff.
Thanks for the help guys, I am pretty sure it will work now.
