Our '87 4R SR5 Honduras Coffee/Missions Rig Build...
Took the back bumper off. What do most people do with the tabs, just cut them off?
-Daniel Kent
37's to big? I'm thinking they might rub. :D
-Daniel Kent
Just got the Tuffy in! First looks seems like a good fit. Not sure if I'll mount the cup holder in the front or rear and move the console the opposite direction. Likely the front.
I think rats may have been in here before and I'm not sure what this funny wiring is about. Had it going to ground looks like.
-Daniel Kent
EDIT: Some how that wire is connected to the rear power window even though it's not connected from where I saw. Power window wouldn't work till I touched it to ground.
Front bumper 1/4 plate support came in. I'll have to find time to weld it on.
-Daniel Kent
Was the wiring between the seats and under the console? If so, those are rear window and wiper.
I knew about the wipers, rear window, but I don't know what the middle push button is.
-Daniel Kent
I believe that might be the rear window lock button?
That's gotta be it! The random rigged ground wire goes to that and if it's not grounded the rear window doesn't work! Thank you sir!
Wonder how to bypass and eliminate it?
-Daniel Kent
Anyone know the back spacing on these? Trying to avoid pulling it off to find out. :)
Thanks!
-Daniel Kent
Thank you for posting the pic with the Tuffy. I've been thinking about getting one and have yet to see a clear picture of one installed. Where did you order it from?
Why do you need to bypass that lock switch? Just don't use the switch.
It's a Series II without the radio. I only bought what it came with. I'm still working on actual mounting. Bought it from 4WD.com for $226.02 shipped.
The switch is missing some parts, I can't see why I would need to use it and bypassing it means one less thing to deal with later. :D
-Daniel Kent
Just happen to have a pair off sitting next to me. Mine measure out at 4-3/8".
Thanks! That's a bummer though cause the steelies I wanna put on are 3.5". I'm assuming that would put my tires to close to the inside. I guess I could do spacers. :(
-Daniel Kent
-Daniel Kent
I think it's the other way around. They will stick out further.
Yep, your right! I just came to that conclusion. Then that is better than the other way around. :) Then looks like a go to put OEM FJ steelies on! Now to powder coat them grey.
-Daniel Kent
Here's the best pic I can find of the color rims I want.
I like the tires on that 40 as well, but I'm leaning towards KM2's 31x10.5x15. Thoughts?
-Daniel Kent
Any luck mounting the Tuffy console? I would love to see how it looks mounted. Recently had my stereo stolen from my '87 and would like to have it more secure in a Tuffy if possible. Not sure how I would deal with the stock moulding and window/wiper switches though.
Talked to a shop about rebuilding our 22RE. It was a lot higher than I was expecting, around $4,500. Looks like I'm buying a new one online for $1,800 shipped!
-Daniel Kent
EDIT: Going with 22REPerformance, but it's a bit more than the above. :D
