OTMT - URGENT Need Help - Hub Studs
I need 3 or more FJ40 hub studs, cone washers, flat washers and nuts. Does anyone have them OR have a dealer that might have them and can bring them to me at McNabb Friday by noonish??? Marshall, JP, David - anyone???
I don't have to have them - but it's the difference between just installing the new studs on the driver side hub and bolting it up and going wheeling - versus pulling the hub and removing the rotor and bearing races to install on my new 6 pin hub... 15 minute job versus 1.5 hours - so no biggie!
Left side is now 6 pins - 2 stock and 4 oversized with the Aisin drilled the same. I have the 6 pin flanges - but McNabb is so far away from State Line I don't want to be driving in 4 wheel drive all the time - plus driving in 4 wheel drive on the return from Schoolbus/Helicopter suks!
I have some but I only have those that are on my hubs I got for my 55. Can I have them back when you are done with them? I don't have extra, I just have mine that I haven't installed yet. I should make it to McNabb around lunch time with the crew coming from ATL.
Marshall - I don't need em that bad - I have 6 in my spare... Not worth pulling em.
Heather - yes - if you are not using and have not installed - please bring them. I won't give them back - will mail you new ones UPS Ground if that works, borrow new - replace with new, etc. You don't want em back after I use them :D.
Studs, cones, nuts, washers - only really need 3 or 4 I think...
Lemme know - it's not that urgent - but I'd like to see what can be worked out.
Thanks to all.
Thanks to all.
I'll bring what I have. And mine aren't new...came of an old piggy I robbed not too long ago. I am sure we can work it out. I just need to have studs before my HAMOM in September.
Bill I believe I have the studs from the 60 series acles I bought a while back, but won't know for sure until I get up to Clemson in the morning......... If I have them I will pull them and bring them for you; well I guess that is if they will work for you......Aisans 60 series???
let me know
