Build Orange's Neverending Scrap 80 Build (the s is silent)
I don't either. I get a much stronger housing out of better steel that'll be easier to weld my link and coil mounts to, I get a 9.5 front and can keep my RCVs and hubs and get to choose my caster angle from the get go
And a front housing can be built out of a rear 9.5" housing without spending the $1k on Ruffstuff
I'll still be doing that. I'm bending factory housings that are trussed and reinforced. Haven't seen people bending the fabbed housings yet
What part of the housing are you bending ?
I was bending at the balls, so then I got another housing and reinforced those right way. Then it seems like the long side tube has a bend in it even though it's been trussed as well. Laser says it's not straight through and axles don't like to come out. Short side I think is ok, but I think the knuckle ball is bent backwards on that side now too just a hair. I'm over it. I spend more time fixing it and replacing seals and stuff in there than I want to
Thank you for the explanation.
Some would argue that the 9.5 is only marginally stronger then a 8" high pinion when run in the front as the 9.5 running in the front is running on the weaker side of the ring gear. 🤷‍♂️
A few things to consider . 1 its not weaker . 2 you now have a matching front and rear 3rd so you can carry 1 spare if you really want to . 3 there is no reason to argue . and 4 i think i have 4 or 5 spare 9.5 3rds if you need one .
Which should be soon. Just waiting on outer balls and Hellfires to become available again
Curious, are you building the 9.5 front to accept the stock inners ? Are the rear axles & front inners same spline ?
Inners are 30 spline front or rear. Most upgrade to 30 spline outers as well from the stock 27 spline .
