just recently noticed a small drop in my oil. I am going to inspect the turbo and add a catch can.
I would like to get an oil analysis done but I have no clue where to get one where I live.
I am curious for someone to compare Rotella T 15/40 with Chevron Delo 15/40 on the 1HD-T
John from radd cruisers swear by 10/40. I want to see in writing what the factory recommends for our 1HD-T
Oils ain't oils
Someone mentioned an article about oil and BEBs earlier in the thread - here it is - and makes interesting reading.
80bigend_oil-analysis-scam.htm
Cheers
Andrew
Nothing beats taking a used filter and opening it up to be convinced. Look at what's inside the famous 90912-30002 Toyota filter (This picture was lifted from this excellent thread on the exploroz forum, hope it's OK, folks!):I've always used Mann filters in the Toyota (I don't know if W940 or what) and I was thinking into moving with the Toyota originals as everyone says they are the best. Do you think the Mann are comparable?. I can get the Mann for 1/2 the price of the Toyota.
Oils ain't oils
Cheers
Andrew
That's what I've done with synthetics...change the filter halfway through. Oil analysis is really the way to find out empirically what the condition of your oil is. Money well spent.
stone what have you found out about your oil analysis's? good, bad?
What oils have this certification? The standard Rotella-T 15W40? The Synth 5W40? or the Synth 0W40?Just bought a pail of Rotella.
It has a JASO rating now!!
Actually he's quite right, from a Toyota white paper I found a few years ago, it would seem the problem is caused by an acoustic harmonic developing in that engine at 2000 RPM, that sends a shock wave sufficient to cause cavitation in the bearings, which can easily explain the type of bearing damage that we've seen...I have an old diesel mechanic with 30 years of toyota experience do my pump and injector work.
He believes there is a vibration in the crank that chews out the soft early type Toyota bearings and he also says its possible that it also kills Toyota rotary pumps on the 1HZ,1HD T as they run off gears directly connected to the crank.
Other rotary pumps on 4 and 6 cyl engines last as long as the inline pumps
Yeah, but WHAT Rotella are you talking about?My last pale of rotella didn't have a jaso rating.
The new one did.
I thought it was mostly the TYPE of acid buffering used, the NA oils using magnesium, the Japanese calcium, which turns out to be better for bearings?From what I have read the japanese have a overly anal soot rating aka JASO MA or something.
