On Board Air Design
Federal Way, WA
I am gathering parts to Install a York based on board air. I am stuck on the air tank. I really don't have room for one. About the only place is underneath just behind the T-Case attached to the bottom side of the cab floor. I can fit between a 1 and 1.5 gallon tank. I may be able to fit a 3 or 4 gallon pancake style tank, but it will be tight. Since the size is so small it won't actually do much other than act to muffle the air pulses. Running hose is going to be an issue (I am not stock). I am going to have a tough time running one hose, much less one house in and one out to the QD ports.
What about the idea of using the tank as more of an accumulator. Run a single hose off a T from the main air line that feeds front and rear QD's? The QD's would be fed this air until pressure drops enough to trigger the York on. If the tank is in a pass through instead it would still act the same way. I am not sure of the benefit of a pass through versus single connection.
Can anyone comment over that design?
Thanks,
Steve
My last 60 had sliders and a rear bumper that were air tanks. I think I did the simple math once and got about 2 gallons between all 3. You could also you roll cage too.
What you describe would work fine.
Try to use a tank however small, as it will fill while you move from tire to tire and you will get some benefit in that.
My opinion only, but I used to design industrial air compressor packages for a living.
I am going to remeasure underneath to see if I can fit a 3 gallon pancake tank. The problem with most tanks that fit is they all use 1/4 NPT fittings. I am designing for 3/8" NPT. If I put one of those tanks inline I just killed the benefit of 3/8".
Hi All
The air tank I used was out of a Range Rover.
The Air Tank mounts nicely up under the drivers side outside chassis rail. ( RHD )
The Air Circuit uses a 5-2 12 volt solenoid valve to direct the Air from the Air pump to the Air On Board tank or to the Air lockers.
This way you do not need to fill the air tank to operate the Air Lockers .
Hope this helps
Some photos .
Cheers
...via IH8MUD app
Huh? Air is compressible. The same volume of air will flow through either fitting, up to a point. It will just be at a higher pressure through the smaller fitting. No matter what size lines you have, all the air has to fit through the tire valve, which is smaller than 1/4" anyway.
If you're running a jackhammer, you need pressure and volume, but you're not.
I use my rollcage as a tank. Just run a line into the cab under the dash and right into the passenger front tube. I kinda wish I had more storage because when your in a jam and the motor isn't running, some reserve air is nice. If your building such a set up plan on running air tools with it, you will be glad you designed it such a way. Why are you using a York? They are massive compressors. I use a fj60 compressor and am very happy with it and its very compact. You could also get some of the slim long hotdog looking torpedo type tanks and put em on the frame rails somewhere. What is a QD port? I dont know what that abbreviation is for
One reason for a tank in what you called pass-through is to help cool the compressed air and trap condensation as it cools. It also helps to trap oil which is normal as compressors wear and for york in particular oil is something to deal with even if it's not worn. But oil can also be addressed with a filter.
One trip mostly as an experiment I ran a hose directly off a york after removing the air chuck core. Compressor on 100%. Walked around the truck filling tires, then turned off the york when done. It worked to fill tires but not for much else. After that mounted a Viair 1 gal tank (91014) and a pressure switch.
Incidentally I later replaced the york with a bendix air brake compressor and later took everything out and went to CO2. Perhaps connect everything you think you want in your driveway, and once happy with how it works then figure out where to mount it. What you start with may not be where you end up.
What is the output of the York? From what I have heard a tank is redundant.
I have the high volume York. At idle it will run about 3 CFM and around 2,000 engine RPM it will put out about 7 cfm. I measured last night and I do have room for a 4 gallon pancake type tank or a 1.5 gallon cylindrical tank. If I never run air tools it might not be worth the tank, but I am leaning towards doing it right the first time.
"QD" quick disconnect.
I have a hard wired twin head electric pump now. It takes me about 4 to 5 minutes per tire to air back up. That is if it doesn't over heat and pop the breaker. The pump is getting worn out as it takes longer and longer to fill the tires. That and I now run 36" Swampers. I know the Yorks are massive, but I have a place to fit it as well as a free York. :)
Some good points, especially the last one. I often end up with something different than I had originally planned on.
I mounted a 2 gallon tank under the tub suspended from a piece of u channel that I bolted onto the frame.
dsc00953-jpg.61892
I have the muffler and T-case output in the way (SBC and 4L60 trans pushed it way back). I only have a 16" square area. That is one of the reasons I posted up. Are tanks even worth it? If so should it be pass through or just dead end in the tank (as an accumulator)?
I am leaning towards spending more and doing it right the first time. It's only an extra hundred. Money grows on trees, right? :)
dsc00953-jpg.61892
I ran a #10 York OBA for years on my Piggy. Also had a 3.5 gallon tank. Ran a 5 piece set of air horns really nice! Using hand throttle to hold around 1800 rpm, I could run 2 hoses out to fill two tires at a time. Never timed it, but seemed to fill 35s up in 3 or 4 minutes each. John
