SOLD NJ: 80 Series - Main Fuel Tank Pump Assy. for Subtank
Status
Not open for further replies.
NJ
  1. 80 Series
  2. LX450
I have 3 of these for sale. $150 each.
Installing an OEM subtank or Long Range America auxilary tank and want the factory main tank transfer inlet pipe? Compared to a N. America spec 80, this assembly has an extra inlet pipe for the transfer pump system that was available in other markets. Push "subtank" on dash and transfer fuel to main tank. Will work with home made auxiliary tank, OEM subtank, or LRA.
One of them has the pump which I do not know the condition of. The level sensor have not been tested. You can swap over your functioning one if INOP.
To confirm - this adds an aux inlet to the main tank (instead of doing a T fitting)
I suppose you could put in a tee to the fuel return line from engine. Only down side is the transfer system will be working against that pressure and be pressurize all the time.
This provides the sub tank it’s own path to the main tank.
Status
