Build New Mexico Pig Build
Will you post updated pics?
Inquiring minds want to know...
No air pump on yours? Looks like it frees up some space under the hood!
Here's a recent pic.
@scrapdaddy
Here's the link:
Ongaro Deluxe Wiper Arm - Flat Tip - 12-18" - 33640
What is the diameter of your current wiper arm spline? From my pile of old wiper arms, I have 2 different spline measurements. I know one size did fit the current wiper motor, but now I'm confused of which one that was. I can get some measurements if you need them.
Also, I had to bend an angle in these new arms to match the stock arms.
Do the ECU controlled wipers work well together? No irritating synch issues? Do you program the ECU to set the arc travel? I'd love to have a better wiper option for my -40.
The description on Ongaro's website leaves a lot to be desired. I can't find an online install manual which would probably answer most my questions.
I originally tried to operate the individual motors without the ecu. They would quickly get out of sync and, after reading up on it, that was to be expected due to all the variables of the dc motors. Once I installed the ecu, it cured that. It's not a seamless operation all the time. Occasionally while switching from high to low or vise versa, they would momentarily get out of sync. The ecu would correct that pretty quickly though. The one thing that I did have problems with was the integrated wiper fluid/ wiper control switch. That made the sync go haywire. I ended up installing a simple push button switch to separately control the wiper fluid pump. The arc travel is adjusted in the motors themselves. You can also set them up to a left or right park position. I'll try to work up a video of the wiper action.
This is my second try at an aftermarket wiper system. Previously I tried the cable drive system. I could never get the excessive play with the wiper arms worked out. It also failed miserably during a snowstorm. This current system is, so far, a better and cheaper solution than the cable drive system.
I don't think it's designed for that. The rear hatch wiper would come on at the same time and in sync with the fronts.
Here's some wiper action for you: exciting stuff;)
So moving!
The raw emotion...
Oh, the humanity!
My latest pig adventure was last week up in the Spanish Peaks in southeast Colorado.
This is West Spanish Peak
I tried to summit a few peaks while I was there, but my new hiking companion would have none of it.
The next day I took the pig up to Trinchera Peak. The road tops out at around 12,770 ft. My pig did not disappoint.
