Build New Mexico Pig Build
That's a good question. I'm leaning towards a UZ swap, but there's a lot more info here in the sty with nearly everyone going with the LS swap.
@fj55-100 , @YukonCruisers , and @TachedOutOffRoad went with UZ engines.
I can’t really comment on anything UZ.
LS on the other hand, I will say, gives you a lot of options to choose from for adapting systems like steering pumps, water pumps, AC compressors, alternators, fuel pumps, fuel lines, wiring, ECM’s, starters, sensors, radiators, hoses, transmission adapters, engine parts, etc…
Don’t ask how much I’ve spent though, not supposed to talk about that.
This is true for the 1UZ as well. If going down that path, the challenging parts are: harness (get from Cartunes in NZ - unless you are an expert, this is the way, ask me how I know); finding a rear sump to install for front axle clearance (most have front sumps). These engins though can be tuned to over 1000hp, so lots of options here as well. Mine isn't done yet, so I can't really talk to performance, but with a Link harness, should be sitting around 300+ without much modification. If I was to do over, I'd probably go LS, fewer headaches, not sure the appeal of 'keep'n her all Toyota' is worth the extended build time.
That's good info!
Maybe Evan @fj55-100 can chime in here. He's the only one I can think of that has been running a UZ in their pig.
LEXUS V8 ENGINES LLC
WIRING SERVICES FOR ENGINE SWAPS
WE DO: 1UZ, 2UZ, 3UZ - MANUAL OR AUTOMATIC
PERFECT FOR ENGINE SWAPS INTO CARS, PICKUP TRUCKS AND BOATS!
We wire up your engine harness, so that you have 3 wires to connect for your engine to run.
We build a fuse box onto your harness with all relays and fuses for circuit and oil protection, so it becomes a standalone system on an OEM management.
We also wire in your alternator, oil light, rev counter, temp gauge, and OBD2 where applicable.
Where OBD1 is relevant, we wire it into your fuse box so that you can read flash codes.
We stock the majority of the connectors if any need to be replaced.
We also bypass your immobilizer or/and flash your ECU if required.
Wiring - $590
Bypass Immobilizer -$140
Flashing ECU - $140
Connectors - Averaging $7-8 per connector installed.
Shipping and Sales tax excluded.
Check out our you tube page for start-ups with various engine harnesses.
lexusv8.com
Lexus V8 Engines LLC​
All Your 1UZ, 2UZ and 3UZ standalone wiring solutions. ECU flashing to suit your build as well as Immobilizer OFF
lexusv8.com
lexusv8.com
You simply send us your engine harness and Ecu. Email us for a client form. Place your client form in your package along with your harness and ecu.
Turnaround time is on average 2/ 3 weeks.
Address: 8124 Alfred Boulevard, Punta Gorda, Florida 33982 USA. USE UPS OR FEDEX. DO NOT USE USPS AS THEY LOSE THE PACKAGES.
www.lexusv8.com
sales@lexusv8.com
