Need help! My first cruiser
anyone know where I can find the cover that goes over the shaft poking out of the back of the transfer case about the top middle? Most of the pics I have seen the cover has been black
thought I would post up another pic of what I got, I would like to here if anyone has incorporated rock sliders into the bottom of the doof frame. I have seen how some people fix the rust problem with a piece of 2x4 tubing, has anyone ever put braces on this and made it into a rock slider? I have started to sift through all the crap today, I have some hard doors I think I am going to sell that are the same color as this but seem to be in good condition if anyone is interested pm or email me.
here is the beast
cntryguy said:
...if anyone has incorporated rock sliders into the bottom of the doof frame
Yep, both custom and "shelf bought"
I think the ones I have are from BTB products installed by the P-PO...Bolt on deal so probably not super heavy duty. 2badfjs sells some (http://www.solidrockoff-road.com/sliders.php) that look real nice. In the end it depends on if you want something that bolts on or welds on...
GL
I am thinking of something that consists of cutting the factory rocker panels off and putting square tube in its place. anyone got any pics or ideas?
If you cut the factory rocker panels off then wouldn't you have no side? We're talking the rocker panel just below the door here right? The rocker panel that ties into the rear of the tub and the front of the cowl?
If you look at the link I posted earlier and check out the two pics at the bottom that might give you some ideas. I'm not sure how far up you could cut before you'd be level with the foot well etc.
Maybe I'm just envisioning it wrong :)
jjhancock said:
I didn't realize that it was a 350 that came out of it, but thought that it was in mid-conversion and in pieces when he got it. Knowing the facts now I disagree with me too :doh:
What does a crate engine go for, anyway?
I got the lowest crate 350 from a chevy dealer for $1400. It was going to be about $1000 to have a shop rebuild my already 30 over 350 so the new one was a good choice. It runs great and its nice not to have anything leaking. Well from the engine anyways...
some people have had bad rust problems so they cut the rocker panels out and install a piece of tubing and reweld the floor to it so yes I guess I do mean cut the side almost all the way off. It seems it would give you better clearance on the sides and the ability to put the vehicles weight on it as long as it was tied into the frame. I am going to try it and not screw it up to bad i hope. I am sure it has been done before by someone I can't be the first to think of this
new pics finally home to the garage
finally got it home to the garage and started cleaning and trying to give it a face. Should have the motor this week, probably wont put it in for a few weeks I am not close to that step. I should really start moving forward in the next few weeks. As you can see it is going to be a long road. Any advice or input is welcome whether I use it or not.
If you still have the PTO stuff, I could use it.
I don't know if you've pulled the transfer case apart, but there's a gear in there that's only on rigs equipped with PTOs. FJ40s with 4 speeds that didn't have a PTO got a spacer instead...If you're tearing stuff apart I could really use that gear too...
Your project looks good though!
Edit: I also have a spare rear cover if you still need it.
I plan on doing the same thing with my rockers. I've got some 2x4 tubing i am going to weld in place and tie it in to the frame with some pipe
if you notice the top pic you can really see how bad the rust ate away at the rocker panel I think this is a great way to incorporate strong sliders right into the body and you really wouldn't even know they were there. Also the PO doesn't know crap about this thing and from more looking it seems it may have lift springs on it anyone know a definite way to tell, measurements? those are 31"'s on it now and it seems to tower over them fairly well. Thanks for the compliments.
sorry man the pto stuff was sold to poser
it almost looks like your rear wheel wells have allready been cut and the fact that you have no front fenders could make the 31"s seem small...im not sure though. the slider idea with cutting out the rocker panel has been done by a few people...i think i might consider it also if i keep bashing mine up once i finally get back to wheeling! nice rig, and the price was right. oh, the cover for the back of your t-case you can probably locate at SOR or maybe 4wheelauto....maybe cdan as well...i think thats his name on mud ne ways...
