Need help! My first cruiser
That looks like a great project. I hope you will continue to update as you go along.
I am going to do the rear spring flip tomorrow, do I need rear shims to correct pinion angle? Anything else needed or is it just simply unbolt springs and turn them around and rebolt? Going to do front as well anything needed there?
How much would you want for your driver's door shipped to Indy?
don't have a clue, make me a reasonable offer and I will probably accept, I can get a pic of it for you tomorrow I know the panels and windows are still in good condition as well, just pm me with an offer
Welcome - I have a stock height FJ with 31's and almost seems I could run 33's. My guess is that if you have a lift it is very mild...I'll be following along with your sheetmetal progress, mine looks about the same and I need some ideas :)
the main reason I think I have a lift is that the springs have a decent arch to them and there is a remnance of a sticker that has been peeled off on them so at minimum they are aftermarket but I am thinking of going to 60 springs for the rear for the wheelbase and the length for flex
Would appreciate pics of your driver side door when you have a chance...especially the bottom area. You can send those to rfeatherston1@aol.com. Will take a look at the pics and send you a PM. Thanks a lot.
Looks like the front axle is a little to the passenger side, or is that just the pic? Oh - what does the SO think about all this? Assume that is her on the passenger floor board. Also - don't get too exuberant at buying parts for the build til you have a plan, you will end up changing ideas and plans many times so buy as you go and take your time. You will end up with a garage sale on Mud if you don't heed the warning :)
I guess I never mentioned the cruiser is stored in her garage because I live in an apartment, guess we better not ever break up. She loves it and is helping me plus her family helpes provide tools so it can't get much better. I am not sure about the axle being towards passenger side, I know the front shackle is bent towards the drivers side, will have to check into that. I can't even make up my mind on suspension so I don't intend to dig into that to soon, slowly but surely
about the front axle, looking at the pic you can tell the angle is from the passenger side, that is what makes it look like the axle is longer on the passenger side, however the springs are crooked on the drivers side, the PO aparently thought 150 lbs of torque was necessary on all shackle bolts, the rears look like they are for springs an inch wider than stock and were just bent in to fit, kinda bs oh well one more thing to fix. If anyone out there has any 60 rear springs they are looking to get rid of let me know.
