Build My Troopy "KABOOM"
I was just looking for a leak today, honest
I found it!
And in the process found a good crack that needed repair
I've given the rig a good look over and baseline after I got it, but this is the kind of thing that pops up.
I'll find other surprises along the way I'm sure, but this is a good solid rig and I'll happily deal with these little things
I found it!
Hi
Can you please specify a bit more precise where and how you found the leak? Was it that crack ore something additional? I recognize the location of the crack, but I'm unable to recognize where this picture of your fixed leak was taken.
I have a leak somewhere in the same area, but was unable to locate it up to now.
Thank you. Regards Ralf
Sure, one of the pics is actually inside the fresh air tunnel,, that houses the wiper assembly ect, you can see screws driven through the bulkhead for various mountings inside, one of them was driven right into the welded seam for the fresh air intake "dam", it separated the lap joint, that's the black sealant you can see, I wish I thought to take a before pic.
Hope that helps you.
After getting it back together this morning, I had to go for a drive.
Visited an old CCC camp, was the main camp for my neck of the woods, not much to take pics of, but its neat to walk around and see what is there, like stone lined pathways outlining among other things the wall tents they lived in.
Mess hall
I assume shower bldg
Paths
Dunno
Installed the rest of the ABS panels from australian door cards, I highly recommend them for either o.e. Masonite blanks or these ABS versions.
Jumpseats should be back from upholstery soon, so that's next.
And bedliner sprayed on the floor once the chemical is back in stock at the shop.
One bit at a time
View attachment 2898080View attachment 2898084
One bit at a time
Those ABS panels are really nice. I tried them before on a previous cruiser I had.
One bit at a time
I love the dogs cushions..
One bit at a time
Dang those look really good. Is that the frontrunner drop down on your door?
