thanks.
sorry i have worked on horizontally opposed 2 cylinders but i get tripped up on this.
1. so it is valve cover, head and then bottom end i guess?
2. you can do the spark plug tube seals by just doing a valve cover gasket?
3. the head comes off (of the bottom end) any time you do a head gasket?
no oil in the coolant. it's bright green.
and the radiator doesn't leak.
i mean for the longest time i just expected to add oil until i could get to the whole thing. ans i guess i would still be thinking this if i don't throw two cylinder misfire codes when running it super hard? one with an old plug and one with a newer 1,000 mile old plug?
i did that little bypass with the resistor for the p0320 code i think it was? thinking i would i clean the throttle body when i did head gasket.
she runs really strong at least as far as i can tell. i was really hammering it on some steep hills for a full day of driving.
You should definitely try and do the headgasket job and film the whole thing for us....
Did you watch the video I posted from Otramm? It walks you through the whole thing, step by step.
