@flintknapper
While I have you here- is there any guideline for sizing the evaporator with the condenser? I noticed that the two are almost the same size, with the condenser being slightly larger. Should that roughly 1:1 ratio be adhered to when adding the rear evaporator,
What you will find in most automotive applications it is a roughly 1:1 ratio (Condenser to Evaporator capacity). This is because they must try and satisfy the cooling needs for ALL folks under all conditions in a particular market. Naturally...that means the unit will be suitable for 'most' but not ideal for everyone. The Engineers try to create system equilibrium as much as that is possible. Thermal and Fluid dynamics being what they are...don't always fit nicely as one package in highly variable conditions.
Is it more of a trial and error and see what works kind of deal? How would you determine what size rear evaporator you could get away with?
Well....I wouldn't characterize it as it 'trial and error' except for cases where the installer doesn't understand/appreciate the relationship of Superheat and Subcooling and their effect on system performance.
I understand your question to be: How important is the Condenser to Evaporator ratio and what will happen if I greatly imbalance the two?
We can pretty much dispense with the idea that we can have too much 'condenser' (capacity from a single unit)...simply because there is limited space to install a larger one. The construction of the condenser (flow type) is more important. But let's say you DO have a condenser with marginally greater heat rejection capacity than your evaporators heat absorbing ability.
The result will be slightly less head pressure and a bit better/faster subcooling...but at some point it becomes wasted because the TXV is going to regulate the superheat at the evaporator anyway. While it is good to have well subcooled liquid refrigerant for the evaporator...during times of low to medium heat load, your system will cycle a lot which will affect the ability of the system to dehumidify the air (not a problem for you desert dwellers).
As for evaporators....YES we can have too much imbalance there. IF we were to have significantly greater evaporator capacity than condenser capacity...then things could go to 'hell in a handbag' pretty quickly.
You would be increasing the superheat load leaving the evaporator(s) which might sound like a good thing. However...it results in higher head pressure and greater demand on the condenser (you better have good air flow).
Also, I was poking around in the front of the truck earlier today and started looking at how much room is really in there for a condenser; there's room for another 2" up top and about 3" on either side compared to this Nissen condenser... would it be worth the trouble to find some other parallel flow or... what was the best one... super cool...? 6" wider and 2" taller than this Nissen?
I'll just give you my thoughts on it and let each person decide whether chasing down the 'ultimate' condenser is worth the efforts required to install/adapt it.
Some considerations:
1. What will be involved in terms of installation (easy, moderate, wish you'd never seen it)?
2. What percent larger is the unit (of same flow type) than the one removed?
3. As installed...are the increased frontal and exit areas actually in the air flow stream or are they sitting over mounts and other obstructions?
4. Is the increase in efficiency in balance with the capacity of the evaporator(s) or is it being wasted?
5. If damaged...can you get a replacement and how long will it take?
Bottom line: It is best to have closely matched capacities (condenser & evaporator) but it will not hurt to have a 'slight' imbalance in favor of the condenser.
The average rear air installation is not going to perform quite as well as the front unit (expect 8-12° difference). It might also prove slightly parasitic to the front unit (so you want a solenoid valve when rear is not used/needed). BUT....if you can get relatively cool air circulating around the passengers/pets in the rear...most are going to be happy campers. The one's that aren't... can get out and walk.
