When is top construction?![]()
Rear sill replacement is next on the line, found interesting reinforcement on both rear corners. Finishing looks more factory then PO repair / Mod. Sorry for the crapy cellphone pics due to low light.
Looks like the rear corners had been patched previously.
Great find with the headlight bezels. I'd have sworn they were FJ25 bezels if you hadn't said anything.
Yeah they definitely look close, although I don't have original bezel to compare with.
Do you know what they came off of? Somewhere on Mud there was a write up about some Jeep(i think) rings that worked.
If it's threaded. Perhaps pad the jaws of a big set of waterpump pliers with chunks of hardwood or thick enough rubber. I'd think heating it up first might help break the bond.
. (Thanks @andybudge for heads up). It was all jammed up not ready to move a bit, however after some CRC spray on internals overnight, it's now working as it should. Wondering how PO managed to bent the pot metal stalk without breaking it
