Hey all. Had some issues with my globe replacement and could use some help/advice.
We bled all 4 globes down
Swapped all globes
Topped up fluid in reservoir
Started truck.
Multiple time trying to get vehicle up. Took a long time but finally moved up. Got into high but wasn’t behaving like normal.
Fluid was always kept in reservoir above
Min.
In a few occasions we lowered the truck and it dropped sorta normal.
Now the “check ahc surtem” code is up and won’t let me lift eh truck.
Truck is low low.
Bled all corners down to try and get back to square 1
Still won’t let me. Just shows the error message and that’s about it.
I’m betting the code is set and won’t clear? No pump action at all now.
Try continuously flipping the switch to the UP position over and over while starting the truck, and keep flipping it up to the up position until it starts flashing UP. Then just let it sit idling for 10 minutes.
ok I'll give that a go.... I'd been doing that and it would read "upP for a second and then go to "lo" and show the error code. won't stay displaying the up
As long as you don't have the AHC warning, the truck will eventually work out getting it to the proper height. The display won't show you that it's doing anything, but if you monitor the pump, you will see that it cycles on and off periodically to get the truck back up to height. This can be seen if you monitor the AHC ECU in Techstream as well. Which is where the suggestion above about letting it idle for a while comes from. I'd stop bleeding but continue to make sure you have enough fluid. Bleeding is just making more work for the pump again.
for sure... its just my pump isn't running and won't run now....
for the first while it was running and getting the vehicle up but now won't run at all. not at start up and not after running for 5-10mins... I'll try letting it sit again. I feel like I triggered an error code in the AHC ECU and it locking out the pump but i'm only guessing....
Looking into getting techstream now... which doesn't seem super easy.
Also picking up a friends fancy diagnostic tool hoping it can maybe clear the code.. Autel MK808
I'll be replacing my globes soon. Did this on my old LX a year ago, but I've already forgotten best practice...
Is it best to bleed and swap one globe at a time, start the car so it levels out, and then move on to the next corner? Seems like that approach may avoid wigging out the system?
This is how I did it, and how I recommend it be done. Seems like once a month we get this same post about someone who did all 4 at once and are having trouble getting the truck back to N.
Not saying it can't work doing all 4 at a time, just that I think it recovers quicker if you do one at a time and gives you better feeling about how it's going. Also, order of operations wise, there's no reason you can't do them individually.
You can try disconnecting battery for a while (20-30min) to get code to clear. OBD Fusion (with extended Lexus pack) / standard Bluetooth OBDII tool might be able to clear the AHC DTC. It can definitely talk to the AHC ECU, just not sure if it can clear codes.
One other tip i can offer, and this isn't really scientific and may not be the right way to do it, so consider at your own risk. The times I've had to get the truck back after lowering all 4 corners to bumps doing bleeding, I've found that pulling the fill valve to the reservoir while it is doing the initial lift can help. The fill valve seems to be a check valve and you end up with a vacuum in the reservoir that works against the pump pulling fluid into the system.
You didn't happen to use black 1 liter plastic containers of AHC fluid did you?
That could plug up the filters on the pump...
If not, keep the cap off of the reservoir and maybe the filter out of the neck while trying all of this. Cap can create a vacuum in the reservoir. Keep flicking the Up button when you start the engine.
you can get a 12v SLA or car battery and connect directly to the pump. Some guys have even run the pump in reverse for a few seconds to get it to prime.
A few users have tried cleaning the pumps. I don't think anyone has separated the two pump halves and gotten it back together properly. If it were me, I'd try to clean the screens without separating the pump and see if I could get it running that way.
This thread has a lot of details...although looks like some of the pictures/videos may be gone now.
