Beware of the aftermarket...
This thing is not producing 120 lumens. The drive current is stated at a very low 125mA. The lumen output at that current is much less - about 10% of the normal output. Yep, that's about 20 lumens (derived from the Luxeon III datasheet, figure 7)
I've been working with high power LED's for automotive applications and there are a lot of people that don't understand how to implement the technology. The most frequent mistake is that the manufacturer (not of the LED, but of the device that uses the LED) makes is a disregard for thermal management. The second one is the proper control circuitry.
When a high power LED is placed in a confined space, heat builds up and that's the #killer of LED's. I doubt that product listed will last you 50k hours, the heat sink doesn't seem to be enough to take the heat away. It might last a few hundred or few thousand hours, but that might be good enough for some. As a benchmark, 10 years of normal vehicle service with the lights on is about 3000 hrs.
$20 is kind of a lot for this product. They are making a pretty good profit on a part that looks like it may be poorly designed. It's my opinion that they should have used a "side emitter" package instead to take advantage of the reflector. If you want to learn more, the datasheets are an interesting read.
If someone wants to buy one for me, I'll test it to see if it's any good. I can take some measurements, read the package temp and calculate the junction temp, put it in an assmelby and see how it survives. Then, of course, publish what I find.
