My 66 FJ40 runs fine around town to the Dog park, home depot etc but we have lot of hill here in Nevada and my cruiser suffers a bit.. going up hill ....I know i run 33" on stock gears.
I had a 2F Rebuilt for me by a local shop about 4 years ago for my 1966 FJ40 finally got It on the road just over a year ago It ran OK, but never seam to have the power like I thought It Should, maybe needs to brake in.
This Summer then I was experiencing some lost of power and a exhaust leak ended and trying to repair It I ended with a Head Gasket leek.
had the Shop go over the head no cracks re surfaced etc. everything good replacing the HG Torqued Anti-seize head bolts to OEM spec. 95 lb. twice, I ran the motor about 50 miles re-torqued, again @ 200 miles lost of power. so i ran a gas leak test on the coolant. came out negative so I ran a compression test.
figuring that I was loosing compression between the cylinders bleeding from cylinder to cylinder
Thinking That would have to start all over with a new HG some one suggested that I try to re torque the head bolts again this time @ 100 lb. once Hot then cold, I did get bit of movement So.... Head bolt stretch ?
I was amazed the compression came up but not to what I was hopping for.
Not an expert on the 2F I went back and read every post On IH8MUD about Head gaskets, Cylinder Heads Open and bathtub Pistons Dome and flat.
this is what I did on my Christmas Vacation
Now The engine Build
So did I have the engine re built with the wrong Pistons ? or do I have the wrong cylinder head ?
or do I have another problem, Bad Rings ?
If I am wrong please let me know my.... thinking is to put in new dome pistons or should I mill the head If so how much what I read .035 to .100 is Ok but how much is too much ?
Thanks to Mace and Mark A for listening too... I know I talked there ear off today.. just want to make run better... Input needed thanks
- Cylinder # 1 - 60
- Cylinder # 2 - 60
- Cylinder # 3 - 55
- Cylinder # 4 - 55
- Cylinder # 5 - 60
- Cylinder # 6 - 55
- Cylinder # 1 - 120
- Cylinder # 2 - 120
- Cylinder # 3 - 110
- Cylinder # 4 - 110
- Cylinder # 5 - 112
- Cylinder # 6 - 110
- The 2F is a mid year 1978 block # 2F 282219 bored .75mm or .30 over new flat top pistons just like what was removed, new oil pump, new cam & Gears lifters bearings
- Cylinder Head 2F 61031 open chamber completely reconditioned
- So what I read is 2F 1975-76 were flat top pistons with bath tub style head ?
- 8/76 - 7/80 had dome pistons and open chamber cylinder head strong head not so good air flow
- 8/80-8/87 bath tub closed chamber better air flow weak head
but he wants a full written report first on the CC of the Cylinder head first...
