Low Compression ?
The low compression is the cylinder head(open chamber) with flat top piston combination you have.
You could surface the head a bit( like .050") or more.
As a side note, I did CC the open chamber head('75 vintage) with a piece of plexiglass and a graduated cylinder, and seem to recall the volume was ~81 CC's on a stock unsurfaced head. I will have to look in my notes to see exactly what the results were... the head has been shaved .040" so I should redo it, and do the calc's to see roughlt what the ratio is per each .010"
If the head has not been cut already, you can take as much as .100 off of it. According to the factory. Who knows, you might be able to take more. Whether that will compensate for the flat top pistons is hard to say. I would expect it would come close. Another option, no mentioned is to fins a closed chamber F head ('69-'72) and install that. you will need to run a line to oil the rocker arms (there are a couple of different and fairly easy ways to do this), but this will gain you significant compression over stock, nt just get back what you have lost with this piston/head combo.
Mark...
how much to shave ? I have no way of knowing what the head original hight was or how much has been shaved off previously I will have to estimate the cc in the combustion chamber before estimating how much to shave from the Cylinder head other wise I think I am shooting in the dark until I start pulling things apart.
I just through away 2 good F heads :doh:
Stock Compression is 7.8 to 1 I provably want to keep It under 9 to 1 just for longevity and use regular gas
Look through this static compression calculator----> RSR Static Compression Ratio Calculator
Maybe with some help from your machine shop friends it will aid...
I have more tech data at my work I can get you tomorrow on overall head thickness and such......I posted it once several years ago but, my clutch is slipping so therefore can't recall...
If you search around here you'll find the topic has been hashed out quite a bit..........
MAF for example claims 0.70 would get you pretty close on the shave........
Last year when I needed domed pistons for my rebuild all of the ITM and Federal Mogul part numbers listed as being correct for 78-80 motors were actually flat tops. I wound up buying pistons from SOR, who had them in stock for an actually very reasonable price. I was a bit surprised when they arrived and were actually from 3 different manufacturer's
Good indicator the well is drying up....
Well, if this head was designed for domed pistons then I guess we don't have to worry about valves smacking into the flat tops. So get another head or play with the one you have... LOL. Have a machine shop take off .030 and try it.
How about pop the head and blueprint it. Do a search. Bolt on a flat plate and fill the void with a syringe. Count the CC's.
Are you confusing a compression test with compression RATIO? The low compression ratio piston/head combo doesn't explain the low compression test results.
Not confusing anything... the 110-120 psi on a fresh rebuild(with the new HG and retorque) is low...
Now, reading further, Dusty reports a flat top piston with a head designed for domed pistons. that equals low compression. even across the board, but low...
Why do you think that 110-120psi is not explained by the improper matching of piston and compression chamber size?
140-150 psi would be more on par...
Joe, if you are bound and determined to take this engine apart again [which incidentally folks, runs better than the one in my 45, which does 80 with a 1bbl...right Mace!] then add me to the chorus that says leave the bottom end alone and shave the head.
And, as I told you on the phone, the constant mis-information being spread about the pistons has to do with the fact that BOTH dome and flat pistons were offered with the open chambered heads from 75-80. The domes went from 1/75 thru 8/76, and the flats from 8/76 on. The vast majority of aftermarket mfgrs are just too lazy to catalog both, so they gloss over this fact.
FLAT WAS standard in 1978. Nonetheless, if you are not satisfied, shave the head.
Best
Mark A.
Mark, I have a stock 79 motor that had dome pistons in it from the factory.
:meh:
I have seen flat top pistons in pre '81 models 2Fs only in a couple of engines that came out of Canada. Every other one I have gone into has OEM domes.
Mark...
Best
Mark A.
Mark ... you are right .... flat top pistons are in my non rebuilt Nov.78 FJ55 IIRC I forgot about that when I did a valve job on it I do remember looking at the pistons, but don't remember what the cylinder head looked like.
since i have just over 6,000 miles on my 2F now perhaps going after the bottom end is not prudent thing to do. and focussing on the top end would be more prudent since I agree with others I did have a breach in the HG @ one time.
Replace the HG and at the same time have the head shaved enough to get me back to the 140 psi+ range I hope.
Looking at my compression # again the ones I did last night pretty much the same. except one cylinder is down to 105 psi but that could be valve adjustment i think ?
but with three cylinders below the 114 psi. Low Limit of FSM (113.8 psi) FSM (149.3) being the high seam to me all i really need is about a 20-30 psi + increases to get me back into the ball park.
I'll get a new HG and things a head of time so the head can go to the machine shop to shave.
and play with the RSR Static Compression Ratio Calculator some more and contemplate how much to shave ?
What about the head bolts should they All be replaced this time I did have a stretch problem getting the bolts to torque properly or should I just borrow by buddies new high $$$ new Torque wrench ?
Thanks Joe C
I say use a late model closed chamber head. Get head from classifieds, and have it gone over, valve job, whatever. When the replacement head is ready, swap it. Seemingly seamless?
update.... I just ran by and checked my other 2F it has the same cylinder head casting #s 61031 :hhmm:
FYI just got off the phone with my Local machine shop here in LV ITM pistons $210.+tax
just thought I put It out there'
You don't trust the eBay dude?
Call him old fashioned; maybe he just wants to support a small business he knows.;)
And he didn't say he was buying the pistons; just checking.
Joe, don't make me come over there and kick you!:flipoff2:
I do not have a problem buying on E-Bay
Not buying pistons, just a FYI on the price got some feed back Today have not done anything.
I like to support our Local Guy still $20. less and no shipping and tax $$ goes into our local economy we need It,
The E-bay guy provably the same price + E-bays % + shipping too
My machinist he has expressed interest of trying to get to the bottom of the low compression issue and has offered to help by discounting his services.
I am still driving the sick whore provably drive It to my Aunt house in Big Pine, Ca through Death Valley on Saturday AM to pick up Greg's FJ80 and back 572 miles round trip. I'll see how It feels when I get back. :cheers:
