- Thread starter
- #21
with the front axle housing being bare bones i dont want to set it up for stock arms or even droped arms thats why im looking at leafs or 3 link
i was thinking that too.. i could awalys have the shackles run off a bumper at the worest or extend some mountsI would measure the front of the frame and the center of the wheel well and see if leaves will even fit. Like someone said 63's are common so you would need about 30" of frame in front of the center of the wheel well. I don't think you will have that.
money is the biggest issue and i realy feel leafs would be the cheapest way to have some real nice lift tbh
What's wrong with the stock front axle? How big of a tire are you planning on running? There are plenty of guys running 6" lifts (keeping the radius arm setup) on the stock axle... running 37s and even 40s. If it's not broken, why fix it?
humm i never knew that very good point. so your saying the 9.5 third would be weak becuse it would be running in reverse?While I think that The OPs idea of a front axle leaf spring conversion is at best foolish idea, replacing the 8 inch front diff with a 9.5 is not. The diff is IMHO the weak link of the rig. I have personally been on hand to see 5 of them fail. Backing up under load, spinning and grabbing traction... BOOM! There go the teeth. Yep, they work great for most of us. Generally speaking the reverse cut teeth and opposite rotation bring it up to acceptable strength for powering forward. But when you have to back up, now you are on the weak side of a tiny little pinion/ring gear. They are not really stout enough for worry free tasking of pushing heavily loaded rigs backwards out of bad spots.
I have no plans to do away with the 8 inch under the front of any of my '80s. I keep telling myself that I use my '80s gently. I am starting to think that my standards may be different than many LOL... but none of my '80s will ever be all out trail rigs. Hopefully the 6th 8 inch reverse cut failure I see won't be one of mine.
Mark...
i do have a deep cut reverre gear set ring and pinWell, any diff is weaker running backwards. So, a 9.5 in the front is weaker than the same 9.5 in the rear (when driving forward). But the 9.5 is stout enough to take the stress when the rig is going forward with no complaints. Most of the time, in most situations the front diff is much more lightly loaded than the rear when you are going forward. It is when you are backing out of a hole that the front diff sees the most load. Whether it is slinging and clawing your way out of a deep mud hole, spinning on ice (and suddenly finding bare frozen sand!!!) or grunting the rig up over a rock lip... when the nose is low and you are backing up hill... that is the time the front diff is taxed. Since the 9.5 is stronger and a non reverse cut diff is running on the strong side when you are backing up, you do not have the concerns that you do with the reverse cut 8 inch in the same situation.
Mark...
While I think that The OPs idea of a front axle leaf spring conversion is at best foolish idea, replacing the 8 inch front diff with a 9.5 is not. The (edit: "Front") diff is IMHO the weak link of the '80. I have personally been on hand to see 5 of them fail. Backing up under load, spinning and grabbing traction... BOOM! There go the teeth. Yep, they work great for most of us. Generally speaking the reverse cut teeth and opposite rotation bring it up to acceptable strength for powering forward. But when you have to back up, now you are on the weak side of a tiny little pinion/ring gear. They are not really stout enough for worry free tasking of pushing heavily loaded rigs backwards out of bad spots.
Mark...
forum.ih8mud.com
forum.ih8mud.com
Six shooters will only fit a mini truck axle. What is your custom 9.5 front made out of? What kind of knuckle balls are on the end of it? The only true high-steer knuckles that fit 80 knuckle balls are Hellfire at about $1100 a pop.i have a 9.5in rear axle cut down adn notched for a front, thinking about 6 shooters the resson i was thinking leafs front and rear is, for the amount of flex with leafs and coils i feel its not the biggest difference. but if i was to left it at least 6.5in for the rear and front wouldi have to extend the arms? or get dropped caster arms? one reason id like leafs in the front is its gonna to be a low cheaper then a 3 link i would assume and as for the rear it should be very easy. i have a set of spare axles to weld on.
