Looking for new rims, need ideas
I wish someone like FJCO would make factory-looking hubcap rims in 16x7 or 16x8. I would be all over 5 of those ASAP.
Check out Nomad wheels...they come in 16x7 and 16x8... I've been following Shannon Campbell on YouTube and he is building a FJ40, thats when I first saw these wheels made by Nomad, they look sick, and they make a stainless optional hubcap that is held on by two counter sunk screws:
504 Field – Nomad Wheels - https://www.nomadwheels.com/collections/504-field?srsltid=AfmBOop4NPVLYdn6riQoAqMZMlMOtW9uNOUkPJ9k4_EtNduLakDMWb4J
“Fifteen52” in 16” w/an easy mod to add clips/caps for a stock look. 17” available. Four color options.
Pic(s) 285/75 16 tire. Mounted using a 2 3/4” lift.
These turned out really well and it was straightforward, it was time consuming to get the 30 holes drilled and tapped for the clips.
We went “round n round” on the selection but, the juice was certainly worth the squeeze..😉
Do you have a link for these rims and clips? These and the Nomads @rustED71 look pretty close to perfect. Only fifteen52 rims I'm seeing for the Cruiser in 16" seem to be the 5 spoke.
I'm a dealer for Nomad, they are super nice
Clips were an EBay purchase. Although I think there are other vendors.
https://www.ebay.com/itm/2866206304...pid=5337589904&customid=&toolid=10001&mkevt=1
With all of the riveted rims being decommissioned, harvesting the clips from them is also an economical option.
Byron, which manuf ? Those look to have a significant backspace, I am looking for 2.5" backspace wheels ?
I used ProComp 7069-5183 wheels which have a -47mm offset, 15x10, 6 on 5.5 pattern. I didn't use any spacers as the disc's had a thicker flange than the drum brakes. The clearance I had was just enough to clear the tie rod ends.
The studs were simply a replacement that I found and were longer than the factory studs. I then turned the threads off the last 1/2" or so and rounded the ends on a small lathe I have. I think this is the place I bought them from.
I forgot to mention. The factory lug nuts are 21mm and you can't get a lug wrench on them with these wheels. I bought some lugs that are 19mm with full seat contact as you can see in the photo.
