Lexus LX450 sunroof
I'm new here, just bought my first Landcruiser, well Lexus, but it's pretty much the same thing. I got a 97 Lexus LX450 fully loaded all options with about 180,000kms (it's Canadian). Everything works great it's in great shape, but the sunroof does not open, my question is, does anyone know if the sunroofs for the Lexus LX450s and the Toyota Landcruisers are the same? Also, maybe someone else that has had this problem might know something about how to fix it.
Thanks
Yes they are the same. Can you please explain "does not open"? In other words, does the motor kick on or not, does it move a little then stop? Have you checked fuse? Folks here are going to ask about the obvious stuff to help.
The motor kicks in, but it does not open or move at all, just makes a noise. I bought it used from a toyota dealership and the guy told me that the motor would need to be replaced or rebuilt, I haven't checked the fuses, but I assume they would have..
You can pull the trim and crank it by hand
Thanks
I have the same issue on my lexus LX450. Where would I find if it is the fuse? Mine is not moving at all nada. Could this be the fuse, switch or motor?
Great thanks for the heads up. by the way where would I find the fuse or check the motor? Or could this just be the switch? At the moment its not doing anything and previous owner said it got stuck what ever that means in his opinion.
Word to the wise, screwing around with the sunroof is a summer project. If it's closed, leave it be. Last thing you want is it not to close correctly right before a snowstorm. Ask me how I know.
This x 1000. Not to mention that if you need to remove those plastic covers, they are VERY brittle. Out of all the ones I have removed, I have only saved 1 or 2 sets. And they are NLA. So take your time and make sure you have multiple pry tools and maybe another set of hands.
Sunroof is on the same fuse as the windows, door locks, seats and a couple other things I think. If any of those things are working it's not the fuse. Fuse is a pink rectangular thing at the bottom of the fuse box.
The ivory trim in our 80 is cracking to pieces. I think this is the right part but it's only available in gray: 63318-60040-A1 - Genuine Toyota MOULDING, SUN ROOF OPENING TRIM
I searched to try to find some info on spraying to match the ivory but only came up with this thread. Anyone have any data? FWIW there are many, many threads on matching the oak trim.
