- Joined
- Jan 8, 2006
- Threads
- 266
- Messages
- 9,823
- Location
- Ashland, OR
- Website
- www.jeffersonstatecruisers.com
I've done some searching, but all the header info is spread around and hard to spot.
So, what are you running, and on what year and engine?
Do you like it/notice the power difference?
Did it fit like it should and have proper emissions connections? (O2 sensor/EGR tubes)
Is it 50 state legal?
Do they still make your header?
I'm going to be rebuilding a 22R for a buddy, and he's thinking about a header while I'm at it... So lets hear it.
. It is a bit loud for my tastes.
I don't honestly notice the power difference since regearing and and adding larger tires. too many different factors have changed since the truck was stock. I think it gives up some low end torque for higher rpm power. I should probably reduce/choke the exhaust a bit unless I install the new cam and head. I have burnt through a few gaskets (possibly due to not retorqueing the header often enough and from not having a flex connector installed in my exhaust) The ceramic finish has held up well. My header exhaust was an "economy replacement" for a broken y pipe and smashed cat and muffler. I am not sure any perceived power gain is worth the hassle or noise.
