let the questions begin
windy wyoming
what goes here? on the floor at front outer edge of driver's seat...1995
There's a plastic hook that's supposed to come out of that hole. There's a matching hole in the floor mat that the hook latches to. It keeps the floor mats from creeping around. Looks like your hook has been broken off.
If that's the actual floor mat we're looking at, then that hole gets hooked.
:beer:
Rookie2
ok, next test...wtf is this? can't pull it out anymore, it drops down between w/s and corner of dash by a pillar on left side.
second pic is where i found it.
man, 40s and 55s are sooooo less complicated for us non technological folks. ;)
I don't think thats stock.
Does it look like it couild be a tube for wiring for an aftermarket gauge? Hard to tell from the pics.
I'll look at it weds.
an antenna for an alarm or remote start?
or a led light?
Ask the PO. Only he will know the answer to that one. Definitely not stock. I like the breathalyzer guess myself. :flipoff2:
-Spike
It's a "convenience" tube for those long road trips where you don't want to stop to use the bathroom, with the case of Pepsi and those that aren't brave enough to wear Depends undergarments. Looks like the funnel attachment for it is missing though. It's coupled to the drain hose for your AC system with a t-fitting so it just drains right out of the bottom of the truck while taking your trip to Moab ;)
x2 on the antenna, you may have an alarm system that you're not aware of.
I wish my '94 had carpet hooks, it's durn irritating to keep moving them back each time I get in, gotta get some of those clip things.
That is obviously the antenna to throw a CEL in case of a HG failure. It also tells the computer when the muffler bearings go bad...
Surely you jest...
Doesn't Gumby know?
What does the drain tube from the sunroof to the body welds look like? I know it goes down the pillar and is the cause of drain stress sometimes. Is this it? I would have guessed it was larger.
It's an after-market left-over of some sort.
If the Gummer put it there you better excercise caution in removing it......:eek:
